wheel bolt retainer rings - Pontiac GTO Forum
 2Likes
post #1 of 12 (permalink) Old 08-08-2019, 09:43 PM Thread Starter
deanhickey's Avatar
Quoted: 38 Post(s)
After trying to separate hub from drum on my 68, unsuccessfully I might add, I noticed three of the studs had a retainer ring of some type at the base. (see pictures) What is the best way to remove these so I can separate the bolt from the hub?
ID:	120715   Click image for larger version
deanhickey is offline
post #2 of 12 (permalink) Old 08-09-2019, 05:07 PM
BLK69JUDGE's Avatar
Quoted: 71 Post(s)
I dont think those come apart ....
do they look like this ? on the back ??
ID:	120727   Click image for larger version
ID:	120729   Click image for larger version
ID:	120731   Click image for larger version
ID:	120733   Click image for larger version
BLK69JUDGE is online now
post #3 of 12 (permalink) Old 08-09-2019, 06:21 PM
GTOJUNIOR's Avatar
Quoted: 68 Post(s)
They look different then the Drum/Lug retainer I've seen before,
but they should just pop off when you drive the lug out.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #4 of 12 (permalink) Old 08-11-2019, 12:48 AM Thread Starter
deanhickey's Avatar
Quoted: 38 Post(s)
They don't look like the ones in your pictures. the hub looks like a normal hub, the face of the drum is different.
post #5 of 12 (permalink) Old 08-11-2019, 12:51 AM Thread Starter
deanhickey's Avatar
Quoted: 38 Post(s)
I have hit them with a chisel and tried to knock the lug out but no luck.
post #6 of 12 (permalink) Old 08-11-2019, 01:02 AM
BLK69JUDGE's Avatar
Quoted: 71 Post(s)
I dont think your s come apart for servicing ....
mine have a slide on drum like the rear
fairly sure yours are press fit and the whole unit gets replaced,,,
Scott
got a picture of the backside of yours ??
post #7 of 12 (permalink) Old 08-11-2019, 02:35 PM
Quoted: 404 Post(s)
If nothing else, the lugs should come out as sometimes you have to replace broken studs.
I have found the trick is to make sure the studs have solid support behind them. Just beating on them may not knock them through because the drum has flex and absorbs the impact.
I find a socket or steel tube that will fit around the back of the stud. Then set that on something solid that fits up into the drum - like a brick or two or..... so you have the drum up off the ground firmly supported by your socket/steel tube. Then beat the stud with the BFH to knock it through.
They sell new drums and new hubs. So if me........ that baby is coming off or going in the trash. But I also have torches and my favorite die grinder/cut-off wheels.
deanhickey likes this.
post #8 of 12 (permalink) Old 08-11-2019, 04:46 PM Thread Starter
deanhickey's Avatar
Quoted: 38 Post(s)
Scott
here is the back side of the hub.
post #9 of 12 (permalink) Old 08-11-2019, 04:58 PM
BLK69JUDGE's Avatar
Quoted: 71 Post(s)
yup
I dont think yours are the 2 piece
headed out to the shop to box a few sold items up and I will take a few more pics...
as I am putting the hubs back on tomorroow....
post #10 of 12 (permalink) Old 08-11-2019, 06:10 PM
Quoted: 404 Post(s)
Interesting. So I pulled out the Restoration book and it says that a different drum & hub assembly were installed on 1968 cars in limited quantity. The drum & hub were separate allowing just the drum to be service. This drum & hub assembly was installed on cars beginning from VIN P268122 (from Dealer Service Information, dated 5-13-1968). So your car may or may not have the 2-piece drum/hub combo even it followed VIN P268122.
If the front drums had to be turned, the hub & drum had to be turned as an assembly.
