Wheel/Tire advice needed for '65 GTO project - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-22-2012, 12:20 AM Thread Starter
I need to get wheels/tires for my '65 GTO project. I have an AirRide suspension but stock body beyond that. I measured that I can stuff an 11" wide tire with a 6" backspace from the rotor surface in the rear. This led me to consider a 275/30R18 as my rear tire starting point. I would like to get as wide a tire as possible in the rear as I will have some decent power to apply to the rear. I have no idea what to do with the front at this point, but suspect they will be slightly narrower in the front.
I also would like some dark gray, black or titanium colored spoke rims but seem to be having trouble finding them in a 5x4.75 pattern.
Any thoughts/ideas/suggestions would be appreciated. Getting close to moving this thing under its own power again but need some wheels/tires first.
Thanks very much!
Fred007 is offline
post #2 of 3 (permalink) Old 04-22-2012, 11:53 AM
Quoted: 119 Post(s)
Backspacing is the main thing. I've had 13 inch wide slicks under my stock '65 on the right rims. My thoughts, and you may not approve of them, but they are mine, is that the large diameter Foose/Ghetto wheels are out of place on these cars and degrade the look of the car. That said, they stiffen up the ride and handle well, due to very little sidewall (which makes the handling great and the ride quality terrible)...I would go with some 15" or 16" diameter American Racing Torque Thrust's.
post #3 of 3 (permalink) Old 04-24-2012, 07:48 PM
I can't remender the front tire size on my 65 when I first got, but they were wide and they were on a 15" rim. I had to go to a samler size because that would rub the outer fender on a good turn. What I have on the front now are P205/65R15.
Chris Holabaugh is offline
Stumble Advice/Help needed Houston67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 10-02-2011 04:08 PM
Serious advice needed dquack 2004-2006 GTO General Discussion 40 11-08-2009 07:58 PM
project 1972 GTO Journal - walk me through and give me advice until it's done. thc301 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 04-30-2007 05:18 PM
Help a brother out... Advice needed!! gtodook 2004-2006 GTO General Discussion 14 11-07-2006 01:55 PM
Opinion/Help needed on gto project. Andymon22 Service, Maintenance and Technical Discussion 4 10-04-2006 11:58 PM
