1965 Toe Kick Panel Install - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-09-2019, 11:31 AM Thread Starter
Quoted: 9 Post(s)
My '65 doesn't have a carpet toe kick panel and i've seen some around for sale, but looking at the panel, and then the area where it should mount, i don't see where the 2 mounting plastic body type fasteners would go to hold the panel on. Seems like on a '68 i had there were a couple of flanges with a hole in each to accept the push in fasteners. The '65 doesn't have them. I've attached a pic of area were it should go, and a pic of the toe kick panel. The only thing that seems to come close is 2 of the bolts of the steering column flange plate that is bolted to the firewall which i don't really think are mounting points. Can someone with a '65 check theirs and see if i may be missing something? Thanks!
ID:	117937   Click image for larger version
wishihaditback is offline
post #2 of 3 (permalink) Old 03-09-2019, 02:27 PM
GTOJUNIOR's Avatar
Quoted: 68 Post(s)
The two holes in the lower column retaining plate are for the push-in rubber plugs to hold the Toe-Plate in.
These are the same/similar to the Firewall pad plugs.
Name:	65 LOWER COLUMN.jpg
ID:	117943   Click image for larger version
Name:	65 LOWER COLUMN TOE PLATE.jpg
ID:	117945   Click image for larger version
Name:	65 LOWER COLUMN TOE PLATE RETAINER.jpg
ID:	117947   Click image for larger version
Name:	FUSE BLOCK 3.jpg
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 3 (permalink) Old 03-09-2019, 02:53 PM Thread Starter
Quoted: 9 Post(s)
Hey thanks GTOJunior! I hadn't even noticed those two places on the column plate, and didn't have a kick plate to see what might line up. I just went and looked again and saw the places you pointed out, which are plugged with what i assume is the seal between the plate and the firewall.Guess they will punch on thru with the fasteners. Thanks a bunch for taking the time to educate me!
Kick panel speakers FlambeauHO 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 13 06-01-2018 08:26 AM
1967 LeMans kick panel removal tiger13 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 10-09-2013 11:17 PM
1967 kick panel question busaben 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 09-19-2013 09:09 AM
65 Kick panel screws Humble 65 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 05-07-2013 08:36 PM
