1968 Gto Wiper Blades Question - Pontiac GTO Forum
post #1 of 8 (permalink) Old 09-16-2019, 07:21 PM Thread Starter
Ebartone's Avatar
Quoted: 16 Post(s)
Well I finally have my wiper motor working, the previous owner crossed a wire on a new harness. Now I see I have the old style arm, and the blade in there is totally free to move in and out, and it does, mostly out! Anyone know of a better blade to use, maybe a part number? Thanks!
ID:	121275   Click image for larger version
Ebartone is online now
post #2 of 8 (permalink) Old 09-17-2019, 02:01 PM Thread Starter
Ebartone's Avatar
Quoted: 16 Post(s)
All - would anyone be willing to post a pic zoomed on on their 68' wiper? I'm curious how others are set up. Thanks!
post #3 of 8 (permalink) Old 09-17-2019, 04:39 PM
O52
O52's Avatar
If you look closely inside the hole you'll notice a little spring loaded "keeper" that locks the post into place. If you flex the blade, that keeper retracts slightly allowing removal from the arm.
ID:	121299   Click image for larger version
ID:	121301   Click image for larger version
Ed
68 GTO (Thanks Mom)
70 El Camino SS
O52 is online now
post #4 of 8 (permalink) Old 09-17-2019, 04:57 PM Thread Starter
Ebartone's Avatar
Quoted: 16 Post(s)
Thank you, this is helpful! Can I ask what blade you used? The rubber blade in mine was not fixed in any way, so it could slide in or out. I'm trying to find a proper replacement....
post #5 of 8 (permalink) Old 09-18-2019, 09:21 AM Thread Starter
Ebartone's Avatar
Quoted: 16 Post(s)
Im starting to wonder if I should just replace both the arm and blade together? Thing is the arm looks original.
post #6 of 8 (permalink) Old 09-18-2019, 10:40 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
Part #: WIP 61633
napa classic blade part number
fairly sure these are correct for our 68-72
take your blade with you for a sample
https://www.google.com/search?q=WIP+...6SdY7AJ7ekOJM:
I sent a few sets to my buddy in australia ,,, they fit perfect ..
the issues I see on my 68 69's is.....
the spring on the under side that holds tension against the windshield rusts ... when they rust the gap in the spring
goes away and the pulling tension is gone ....
also when they get week ,,, the drivers side will rub on your hood chrome trim .... and the wiper arm will show a black mark right on the elbow ....
also the flat arm drivers side lock clip should be examined very closely... slide the clip back gently ,,,,
sometimes you need to tap lightly with a screwdriver on the lip of the clip and slide it back....
slide it back and check the "PIN" slot that the clip rides in ,.,,, some time with use I have seen them cut right
thru the groove the clip sits in and the wiper arm goes BONKERS and screws up alot a stuff..
windshields.. trim ... wiper arm .... and you cant see because u need the wipers...
please watch a you tube video if you never pulled a wiper arm off a GM like this ... theres a bit of a trick
to keep from scratchin things up put a rag under your pry tool ...
Scott
ID:	121343   Click image for larger version
ID:	121345   Click image for larger version
ID:	121347   Click image for larger version
ID:	121349   Click image for larger version
ID:	121353   Click image for larger version
ID:	121355   Click image for larger version
ID:	121357   Click image for larger version
ID:	121359   Click image for larger version
BLK69JUDGE is online now
post #7 of 8 (permalink) Old 09-19-2019, 05:33 AM Thread Starter
Ebartone's Avatar
Quoted: 16 Post(s)
Awesome, thanks very much for the help, and time you put into this! Yea, after a long battle finally getting the wiper wired right, and replaced, the rubber blade has been actually slipping out of the metal arm, and so like many other things on my new goat, my plan is simply to replace it, to make it my own! At first I was just looking for a new rubber blade, assuming there is something missing from my current one that is allowing it to slip out, but based on this Iíll just get new arms and blades together. Not that I ever intend for it to go out in the rain anyway! Thank you!
post #8 of 8 (permalink) Old 09-19-2019, 10:20 AM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
your welcome ...
I just happend to be in the tub next to it and remembered your post...
and pulled em out for pics
just blade and blade holders ... is all youlle need ...
keep YOUR arms ....if they feel nice and springee towards the windshield
easiest if the wipers are in the ..at rest down position if you need to remove them
