1970 Dash Bulb Replacement - Pontiac GTO Forum
 1Likes
  • 1 Post By Judgezilla
post #1 of 8 (permalink) Old 01-21-2017, 03:17 PM Thread Starter
GoatBawb's Avatar
So I am still pretty new to my 70 Goat. Is there any way to get to the gauge cluster bulbs without pulling the whole dash out? I think all but two are burnt out, and I really don't want to get into pulling the whole dash out right now. Thanks.
GoatBawb is offline
post #2 of 8 (permalink) Old 01-22-2017, 12:25 PM
1968gto421's Avatar
Quoted: 70 Post(s)
I should think that despite the busy-ness under the dash you should be able to reach up under there and do it, You might have to lie on your back on the floor with your head near the pedals to see but it's been done on my '68. (That's the joy of the '64-65's as hey are relatively uncluttered under the dash!!)
Keep us posted.
1968gto421 is offline
post #3 of 8 (permalink) Old 01-23-2017, 12:09 PM Thread Starter
GoatBawb's Avatar
I will take a look this weekend............yes my '65 Grand Prix was much easier to get into the dash. I am amazed at what all chnged in the electricals in just 5 years. Thanks.
GoatBawb is offline
post #4 of 8 (permalink) Old 01-24-2017, 10:34 AM
1968gto421's Avatar
Quoted: 70 Post(s)
Too true! My '68 looks more like my wife's Chevy HHR under the dash than like my brother's "65 Chevelle, unbelievable.
post #5 of 8 (permalink) Old 01-29-2017, 01:46 PM
you should be able to get your hand in there. It wont be easy for sure. When rebuilding my dash i found that most bulbs worked. just needed a little sand paper on the connectors.
FooGee is offline
post #6 of 8 (permalink) Old 01-30-2017, 03:56 AM
Judgezilla's Avatar
Location: St. Clair Shores, just within sniffing distance of Detroit
To make thing easy when I changed to LED dash bulbs, I took the drivers' seat out (about two minutes). I then used a folded blanket to lay on my back comfortably, and with a small flashlight, I was able to see every light on the back of the dash.
AC Man12 likes this.
Judgezilla is offline
post #7 of 8 (permalink) Old 01-31-2017, 11:58 AM Thread Starter
GoatBawb's Avatar
Good idea.........it poured rain all weekend, so I may try again to get it in the driveway so I can sprawl out under there (I'm 6'4 and my garage is a little too cramped for the head-under-the dash-legs-out-door position. Thanks all for the advice.
GoatBawb is offline
post #8 of 8 (permalink) Old 02-20-2017, 01:56 PM Thread Starter
GoatBawb's Avatar
So finally a productive weekend. Got my bulbs replaced, tach and gauges installed, new radio and amp installed, and an Ames dash cap on there. I'm really happy with the cap; I was a little hesitant but definitely looks good. I had to trim a little around the glove box; I used aviation cutters and then some 80-grit sandpaper. A tip I lerned from YouTube: use weathersrip adhesive all over it, and use rolls of paper towels between the windshield and cap until it dries. I will try to post some pics of the during and after.
Name:	DASH INSTALL.jpg
ID:	87257   Click image for larger version
Name:	DASH AFTER.jpg
GoatBawb is offline
Dash gauge bezel replacement alanmay0 1964-1974 Tempest, Lemans & GTO General Discussion 3 12-10-2016 09:52 PM
1966 gto bulb replacement scoob 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 09-05-2012 01:40 AM
Light Bulb Replacement sazaisan Service, Maintenance and Technical Discussion 1 06-05-2011 02:49 PM
66 Goat dash replacement? DukeB-120th 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 10-26-2009 08:34 AM
Replacement of bulb for fan speed control rick3452 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 08-30-2008 11:02 AM
