1970 Lemans steering wheel catches - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-29-2017, 08:00 PM Thread Starter
I'm currently am having some trouble with my 70 Lemans steering wheel, when I'm driving at certain points when I'm turning it will slightly get caught up and not turn without a little bit more pressure.
It all started when I took the wheel off to straighten it and when I put it back on and tightened down I felt it it kinda pop into place. Likewise the horn now is constantly going off and I had to disconnect the horn relay.
Did I tighten it down too much and knock a bearing off causing it now to catch? Or could it be something else?
Mage0095 is offline
post #2 of 5 (permalink) Old 06-29-2017, 11:17 PM
zzomby's Avatar
Steering knuckle hits the exhaust bolt on mine.
zzomby is offline
post #3 of 5 (permalink) Old 06-30-2017, 01:45 PM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
sounds like maybe
you blew apart the cancel cam coming up thru the steering wheel
time to pull it apart
I havent had much luck on the 69 n newer ... centering the steering wheel that way
BLK69JUDGE is online now
post #4 of 5 (permalink) Old 06-30-2017, 11:37 PM Thread Starter
I looked and nothing is catching in the engine bay. I took the wheel apart today and before I did when the wheel turned I could hear it grinding slightly.
The canceling cam didn't appear to be broken.
I did notice the shaft in the wheel that everything bolts onto and around does move in and out about an 1" or 3/4". Is that normal?
Also the part that gets pressed down and and holds the canceling cam down is bent a little. It happened when I was pressing it back into place, could this also be catching on something in the wheel?
Mage0095 is offline
post #5 of 5 (permalink) Old 07-01-2017, 10:48 AM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
maybe
Jack the front tires off the ground and have some one turn the tires left n right while you listen inside...
1970 lemans steering wheel Mage0095 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 05-26-2016 02:21 PM
How to remove the horn button from a custom sport steering wheel on a 1970 GTO? Grant1969 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 11-08-2015 08:38 PM
64 Lemans Steering Wheel spuzzy 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 04-28-2015 08:25 AM
Need Photo of 70 LeMans Steering Wheel beertracker 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 01-31-2010 10:33 PM
