65 GTO rear seatback removal - Pontiac GTO Forum
post #1 of 7 (permalink) Old 07-31-2018, 05:08 AM Thread Starter
ERIC60's Avatar
Quoted: 4 Post(s)
hello guys,
what is the best way to remove the rear seatback on my 65 GTO?
is it a hook to unlatch or bolts to release?
the carpet is so closed from bottom of the seat that I can barely run my fingers and I can't see nothing!
please help!!!
ERIC60 is offline
post #2 of 7 (permalink) Old 07-31-2018, 05:30 AM
Joe'sToy's Avatar
Eric,
Remove the bottom seat first, it has two points that latch behind two hold down brackets on the floor. Just push straight back and then lift up. Once you have the bottom seat removed, you'll see that there are another two metal clamps that fold down over two retainers on the backside seat. Bend those up and then pull the bottom of the seat forward and at the same time push straight up, the seat back will then be free to lift off the two top hooks that lock the seat back.
Depending on how tight your seats are, you may have to remove the rear armrests as well, so the seat bottom and top will clear.
Joe.
Joe'sToy is offline
post #3 of 7 (permalink) Old 07-31-2018, 05:36 AM Thread Starter
ERIC60's Avatar
Quoted: 4 Post(s)
hey joe, thanks for prompt reply;
where are located the brackets?
in the center, close to the transmission tunnel or on the sides?
ERIC60 is offline
post #4 of 7 (permalink) Old 07-31-2018, 10:17 AM
Quoted: 78 Post(s)
I believe you push down and back on the seat to release the frame from the hook brackets. Takes some effort.
Shake-N-Bake is offline
post #5 of 7 (permalink) Old 07-31-2018, 10:18 AM
Quoted: 78 Post(s)
Oops, I misread the question. I thought you were asking about the lower section. Sorry.
post #6 of 7 (permalink) Old 08-01-2018, 06:21 PM
Joe'sToy's Avatar
For the bottom seat, the brackets on the floor are about 6"-8" in from each side. The brackets for the rear seat back are about the same distance just at the rear bottom of the seat, you'll see them once the bottom seat is removed.
Joe'sToy is offline
post #7 of 7 (permalink) Old 08-02-2018, 01:50 AM Thread Starter
ERIC60's Avatar
Quoted: 4 Post(s)
ok, thanks;
cheers;
ERIC60 is offline
package tray, rear seatback, etc. Stereolab42 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 07-29-2018 09:03 PM
Drivers seatback problems... Forum Poster Interior Discussions 0 08-25-2015 10:40 PM
65 GTO door removal bluegoat2033 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 10 11-08-2008 10:42 AM
Seatback Panel dchaver Interior Discussions 8 01-23-2008 08:09 AM
