68 Convertible Door verticle window channel replacement - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-29-2016, 09:18 AM Thread Starter
Quoted: 4 Post(s)
Hello, Need some help replacing the vertical rubber channel on a 68 GTO convertible that sits between the ventilator window and the door glass. It fits behind the ventilator division channel and wraps around the door glass. I'm not sure if one piece goes all the way down into the door for the full up and down travel of the window, or if there is an upper part of the channel and a lower part. The 68 Fisher Body Service Manual shows an upper and lower part, but it's not clear how it is removed and replaced. In any case, does anyone know how to replaced one of these channels? Any help would be appreciated. Thanks
mwatson1647 is offline
post #2 of 2 (permalink) Old 06-07-2016, 12:55 PM
68GTO4004Spd's Avatar
It's a one piece deal with a molded part at the top. You will have to pull the vent window assy out of the door. Here is a link to Ames catalog for part.
https://secure.amesperf.com/qilan/De...A&web_access=Y
68GTO4004Spd is offline
Rear window channel OrbitOrange 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 11-21-2010 10:33 PM
64 rear window channel rot 64tempest 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 08-30-2009 02:03 PM
Window channel question Chris Holabaugh 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 04-01-2009 09:43 AM
