69 instrument cluster grounds - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-25-2015, 12:19 PM Thread Starter
Quoted: 14 Post(s)
Doing a test assembly on my 69 dash. Can't remember how many of those flat metal ground straps are connected to the cluster and where on the cluster they go. Thanks
greenjudge69 is offline
post #2 of 4 (permalink) Old 10-25-2015, 04:20 PM
Location doesn't really matter, just make sure that they're all connected to each other somehow. The main ground path for the whole panel is through all those straps, to the metal core of the dash, and into the rest of the body via the two big mounting bolts at the lower corners near both doors. You'll want to make sure you've got good metal to metal contact at all those points (no paint).
post #3 of 4 (permalink) Old 10-25-2015, 04:34 PM Thread Starter
Quoted: 14 Post(s)
Thanks for your help. Does anyone repo the roof rail weatherstrip channels for a 69? I see them for a 69 chevelle.
post #4 of 4 (permalink) Old 12-26-2015, 06:00 PM
dan woodland's Avatar
Quoted: 34 Post(s)
Here is where mine are/will be when I rebuild my dash... between the clock and speedo assembly.
Speedo assembly to the dash... I think this is by the wiper switch connection.
dan woodland is offline
67 Instrument cluster rexjet Interior Discussions 2 12-23-2014 03:54 PM
Instrument cluster removal RGT Interior Discussions 5 11-09-2012 04:30 PM
66 instrument cluster stevebrochu 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 11-09-2012 01:46 AM
Restoration of my Instrument Cluster?? Mr66GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 05-28-2011 07:32 PM
64 Instrument Cluster GTOKID64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-13-2010 06:27 PM
