Bleeding convertible pump, lines, and cylinders properly - Pontiac GTO Forum
post #1 of 12 (permalink) Old 01-02-2018, 08:05 AM Thread Starter
Quoted: 126 Post(s)
OK I have seen a few threads on "purging" the fluid in the convertible system and most refer to the AMES kit. I have the AMES kit and the instructions and it really is not a true purge. Really all the kit does is "top off" / fill the system by connecting an external tupperware piece filled with ATF to the fill plug.
How did you guys purge the old fluid ? The AMES instructions really are about "filling". Do you just use gravity method ?
Has anyone connected a pressure gauge to determine if the pump is strong enough ?
Also I have not found any specifications on the pump to determine if it is within operating standards (i.e. current draw, fluid PSI, etc.).
I see AMES and eBay both seem to sell replacement pumps for ~$230 - $260. Are there any better (stronger and more reliable) options?
Thanks in advance!
Chris
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #2 of 12 (permalink) Old 01-02-2018, 09:52 AM Thread Starter
Quoted: 126 Post(s)
Here is a copy and paste from a Chenille site and claims to be from Fisher Body Service Manual 1969:
FILLING OF HYDRO-LECTRIC RESERVOIR
This procedure virtually eliminates discharge or spillage of hydraulic fluid and possible trim damage while filling and bleeding system.
Fabrication of Rubber Filler Plug Adapter
Obtain a spare rubber filler plug (Part #7596442 ). Might have to improvise here, as I’m sure these are no longer available.
Cut approximately ½” off male end of plug (end inserted into reservoir) to permit insertion of tubing as shown in sketch. Sorry, can’t copy the illustration from the manual.
Obtain a 2” length of metal tubing 7/32” OD x 5/32” ID.
Insert reworked plug into filler hole in reservoir.
Insert metal tubing through hole in reworked filler plug.
Filling and Bleeding Reservoir
On all body styles, with top in raised position, remove folding top compartment bag material from rear seat back panel.
On “B-C & F” body styles (full-size cars and Camaro/Firebird) remove rear seat cushion and back.
Place absorbent rags below reservoir at filler plug. Using pliers, slowly pull filler plug from reservoir.
IMPORTANT: When installing new or overhauled motor and pump assembly as a bench operation, fill reservoir with hydraulic fluid. This priming operation is necessary prior to performing the following steps in order to avoid drawing excessive amount of air into hydraulic system.
Install filler plug adapter to reservoir (already done in a previous step!) and attach 4 or 5 foot length 5/32 inch ID rubber tubing or hose to filler plug tubing.
Install opposite end of hose into a container of Type “A” transmission fluid.
NOTE: Container should be placed in rear compartment (trunk) area on “A” bodies (Chevelle, Cutlass, Tempest, Skylark) and rear floor pan on “B-C & F” bodies, below level of fluid in reservoir. In addition, sufficient fluid must be available in container to avoid drawing air into hydraulic system. (Again, an illustration is referenced here, but I cannot copy it into this document…sorry.)
Operate top to down or stacked position. After top is fully lowered continue to operate motor and pump assembly approximately 15 to 20 seconds, or until noise level of pump is noticeably reduced. Reduction in pump noise level indicates that hydraulic system is filled with fluid.
Operate top up and down several times or until operation of top is consistently smooth in both up and down cycles and no further air bubbles are exhausted in container of fluid.
With top in down position, remove filler plug tubing and remove filler plug adapter from reservoir.
Check level of fluid in reservoir and re-install original filler hole plug.
NOTE: Fluid level should be within ¼” of lower edge of filler plug with top in down position.
CAUTION: DO NOT OVERFILL.
Current setup:
4 speed Muncie
cij911 is offline
post #3 of 12 (permalink) Old 01-02-2018, 09:59 AM
60sPontiacs's Avatar
I see you found something while I was writing this, but will attach what I did.
I dug into this for a 67 GP. Was working okay until I tried topping it off, then fluid seeped past pump (small o-ring on shaft) into motor and that was the end of it. Old GM cars (pre-68?) used brake fluid, newers used ATF - I think I used hydraulic (or convert top) fluid but can't find bottle in garage w/quick look.
Ah-found this link from when I discussed this on other forum (almost 3 years ago..).
67 Pontiac convertible fluid type, leak, and add - Hot Rod Forum : Hotrodders Bulletin Board
I used this kit.. $20, cheap.
https://www.ebay.com/itm/1955-And-Ne...dDPaAw&vxp=mtr
These guys are good, but the "green" armature o-ring may not be green. It's same size but different material than two other o-rings in the kit. Black one seals, but being on an armature instead of static seal, I'd want the green (viton?) seal. Check around and maybe call vendors to confirm. I'm not sure if these (Hydroelectric) are the guys I got that kit from (whoever it was, changed their ad so it no longer said "green").
Pull the back seat if not already done. Pull armrest/whatever on sides so you can access/see everything and check for leaks. Good to take photos so if you pull all apart, you'll know how it all goes back together/lines are routed.
To "purge" air from lines, all you do is raise/lower top a few times. I can't remember sequence, but you fill it when top's either up or down (of course one or other, but it matters so you need to know..). With back seat removed, you'll see air bubbles in lines disappear as you do this.
To "flush" the pump, cylinders, and lines...
1) I'd remove the pump and rebuild it on a bench. Is easy. Problem with no power is either with motor (fluid leaked into it) or the check ball areas are gunked up. Pull it apart before you order a rebuild kit - if motor is bad, you need a different pump. Test the motor using jumper cables (don't run pump dry for long.. there should be enough fluid in it to test motor briefly - my bad motor growled and got hot fast).
2) I flushed cylinders by removing them, then moving rod up and down manually while collecting fluid (to see if gunk was inside). You can pull clean fluid back into them and flush out a few times. This can be messy - fluid will squirt far... proper way would be attaching lines and using a can to collect old stuff, separate can/ATF bottle to supply new fluid). Pushing or pulling rod makes fluid come out of top or bottom of cylinder, while it'd pull fluid into bottom or top. When removing cylinders, keep track of hardware, plastic bushings, wavy spring washers, etc (maybe stuff a rag into an opening, where if anything fell/bounced into, it'd be hard to get it out
3) Lines can get sediment in them - blow them out with compressed air, then maybe hook a clean tube to one end and suck clean fluid into them, then blow it out with compressed air. Seems if ATF, could use a can of transmission line flush. I wouldn't be concerned about getting these squeaky clean inside. If you pull lines, you could attach and flush them while flushing cylinders.
Curious about your symptoms.
Top doesn't go up at all, Top goes up crooked, leaks, air in lines, goes up but labored, etc
My switch was bad - didn't get enough current to pump motor. You can test this by hooking 12 volts directly to motor (there's a common line, then one each for up and down). Motor also needs to be grounded well in trunk.
I never read anything about anyone needing a more powerful pump. I ended up getting a used Mustang pump for $50/ebay for the GP and just had to change with the mount (maybe transferred pump to motor?? my memory is bad, but it still works fine...).
I had no problems removing hydraulic lines. IIRC, all were brass swivel connections that came off easily (I used a tubing wrench, but a good open end would probably work). These lines can be brittle and crack/snap, but then they needed replacing anyway... not too expensive.
http://www.hydroe.com/product_detail...e%20Hose%20Set
Lots of good info on HydroElectric site.
Chris
60sPontiacs is offline
post #4 of 12 (permalink) Old 01-02-2018, 10:17 AM Thread Starter
Quoted: 126 Post(s)
Thanks 60sPontiacs!!
I am restoring my 65' tripower and the car is pretty much gutted at this point so I figured it would be an easy time to change the fluid. Currently the top operates - fine going down and temperamental going up. The motor / pump look old from the outside and honestly I cannot see the fluid in the lines, so I suspect it is brake fluid rather than red ATF.
My plan is to disconnect the lines at the base of each cylinder and let the fluid drain into a pan under each cylinder. Then I plan on cycling the pump and pushing out the old fluid into said pans. Then I will fill the pump as much as possible and use the AMES tupperware procedure to do a proper fill.
Once the new fluid is in, I plan on running it a few times and listening / looking for leaks. Based upon the results I will decide next steps - leave alone, replace pump / motor (~$230), replace cylinders, or replace everything.
I plan on making a video to share with other neophytes (like myself).
Chris
Current setup:
4 speed Muncie
cij911 is offline
post #5 of 12 (permalink) Old 01-02-2018, 02:12 PM
Nice car. It's something to hear from the actual owners of these classic GTOs (like your tri-power 65 convertible).
All these years with convertibles and my mind still struggles with if "top down" means opened or closed - it goes UP from my head when I open it and comes DOWN toward me when closing. I assume you mean top is OPEN when DOWN (this is MY problem... not with the rest of the world... when someone says put the top down, they always mean open it..).
When the piston is at the bottom of the cylinder, not much fluid will come out of the bottom hole (I think this is when top's closed) - the fluid would be in the top portion of cylinder... and not much would come out anyway because the cylinder is sealed at the piston (an equal volume of air has to go in through the opening for fluid to come out, which will be very slow with fluid through ~3/32" opening)... it wouldn't let air in even if you open the top line because the piston blocks it. And if you move the top, it can come squirting out fast and make a mess - is bad with corrosive (to eyes and paint) brake fluid. Tying a rag around it will stop fluid from going everywhere, but there's no danger of anything but dribbles unless the top/pistons or pump moves when lines are disconnected (nothing's pressurized with all at rest). Probably a good idea to wear goggles so fluid doesn't get in eyes if something happened fast.
It's hard to tell if the lines are full/empty with clear fluid, unless you can see bubbles. If top goes up/not down (or visa versa) it sounds like you're either very low on fluid or one of the check balls/valves are stuck. I'd think the pump/motor is good. Big hint is if the motor spins fast in one direction - been a while, but think when it did this I could see bubbles in the lines. This (working in one direction) would also seem to mean the pistons are sealing okay - if not (it seems) fluid would go past them in both directions.
Just did a search about mixing fluids/what to use... this is the toughest part of working on these.
https://www.google.com/search?q=can+...utf-8&oe=utf-8
Chevy guys are back and forth (because of changes in fluids/ages of cars), though BigDave (post 8) suggested flushing out old brake fluid and using Dot 5 silicone fluid (great idea, and silicone's good on rubber), since (it seems [my eternal disclaimer]) that new brake fluids should mix with some old residue without problem (brake fluid changes are common, but I don't know if systems have to be flushed with denatured alcohol or something first). Other problem with brake fluid is it absorbs water so can rust insides (though don't think pump had steel components other than check balls).
Convertible top pump fluid ? ? - Impala Tech
Mercedes guys are adamant about using the exact right stuff. Looks like some good general knowledge down the page.
https://mbworld.org/forums/clk-class...ge-system.html
The whole point is trying to save money on parts. I think you can get new everything (cylinders, pump, lines, mounts) for about $600 - then use ATF and you'll be set for good. Some diehard resto guys might want to use original everything (including brake fluid) but that's each owner's business.
I'd be concerned about the pump seal leaking into the motor - especially if brake fluid's been working on a 50 year old rubber o-ring. There could be some leaking into the motor without causing damage. Maybe what I did was create pressure in the system when I filled it (top going up creates much more pressure than down, or v-v), and fluid went into the motor. When I opened the motor, it was a mess. For $20 it's worth a kit to learn about it - and you get 21st century neoprene seals (and maybe a viton? for the armature) .
It was easy to pull the cylinders - no tight spots to get wrench, etc. and then you can inspect the shoulder pivot bolts, plastic bushings, etc. I think Ames sells bushings etc. Flushing them as I said allows you to clear out crap that may be settled on top of the piston. Common problem is fluid leaking from tops of cylinders - they'll work fine if a small leak, but could cause the symptom you see if a bad leak... piston is sealed, but when it's going down, pressure is pushing against the rod's seal, and when piston is going up pressure is pushing against closed end of cylinder.
I reread your post - if you open the bottom line and running the pump, it should pump fluid out - probably good enough, but I'd still disassemble, look at, and rebuild the pump (because of old seals). .
Chris
post #6 of 12 (permalink) Old 01-02-2018, 06:40 PM Thread Starter
Quoted: 126 Post(s)
Again HUGE thanks 60sPontiacs!!!
Not exactly sure what the problem is, but my lines still appear to have a TON of air in them. The cylinders go up and down, but the system does not appear to be purging air as I thought it should / would. Additionally I cannot understand how the tupperware full of ATF will get sucked up (doesn't appear to) ? Maybe my seals are bad (ordered a rebuild kit), but I'm certainly not getting enough vacuum to draw the fluid up.
Thoughts ?
Thanks again!
Current setup:
4 speed Muncie
cij911 is offline
post #7 of 12 (permalink) Old 01-02-2018, 08:44 PM
Pumps like this don't really create vacuum. They have a lot of output pressure, which is why you fill the reservoir and run it to pump fluid through the lines. Eventually the bubbles get back to the reservoir where they float to the top, and air-free fluid is pumped back into the lines.
Come to think of it, the three tops I've had trouble with opened (with the pump) easier than closing. Not sure why, though if it's MUCH easier for the top to open, maybe the air compresses enough to do so, but not enough to close it. This might be true because it IS much easier to push open the top from inside the car than it is to lift it out of the well to close it (I'd always assumed I was fighting fluid in lines but maybe it's also mechanics of the weight).
Is your back seat out? If so and it's leaking from the top of cylinder(s), there will be fluid under the back seat. You should also be able to see bubbles in the lines, but I'd hold off trying to fill it until you get a look at your pump to make sure the armature seal is holding. The GP pump worked fine until I filled it.
The HydroElectric site said have 3 quarts of fluid to fill a system, so might take a lot if empty, but I'd expect yours to be at least half full if the top opens.
Are you trying to "suck" up ATF from a container to feed it into the lines? If you have brake fluid, you'd be mixing the two, and that might not be good. You can research if there are problems with doing this - everyone I've read says not to, but I haven't seen anything from someone who did it/said it was okay. And it might not cause a problem right away, but could in time. You don't want to damage the piston seals. The pump wouldn't matter since there's no rubber in it (the actual pump mechanism) except for the o-ring the seals. Loosen a line to see if the liquid smells like brake fluid.
I haven't seen the Ames procedure - tried a brief search. Is there an inet link where I can see it?
Chris
post #8 of 12 (permalink) Old 01-04-2018, 10:51 AM Thread Starter
Quoted: 126 Post(s)
Well my pump is shot, so I ordered a new one from Hydro-electric...Hopefully this fixes the problem .
Current setup:
4 speed Muncie
cij911 is offline
post #9 of 12 (permalink) Old 01-04-2018, 12:13 PM
How so? Motor bad?
Did you figure out which fluid you have/will use?
Chris
post #10 of 12 (permalink) Old 01-06-2018, 07:11 AM Thread Starter
Quoted: 126 Post(s)
Originally Posted by 60sPontiacs View Post
How so? Motor bad?
The pump was not creating enough pressure to raise the top....
I will use ATF as that is what is recommended by the manufacturer and won't damage the paint if it leaks.
Thanks for your help!
Current setup:
4 speed Muncie
cij911 is offline
Replacing Convertible Pump Tubing with metal lines archlab 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 03-21-2016 04:24 PM
67 gto fuel pump,lines, starter questions 42willys 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 16 04-14-2015 03:05 PM
1967 gto convertible top motor oil/bleeding 67gtoconv 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 05-09-2014 12:22 PM
Convertible Top Bleeding Issue chin 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 11 11-02-2013 11:25 PM
65 GTO Convertible Top pump fluid lines olde-goat 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 03-27-2011 08:41 AM
