Correct Transmission Hole in Floor? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-10-2017, 07:25 PM Thread Starter
Quoted: 12 Post(s)
Hi folks. Redoing a '67 GTO. This thin came form the factory with an automatic in it and at some point the owner cut a hole in the floor and put in a 4 speed. When I say cut a hole, I mean it. This thing looks like it was done with leftover parts from the workbench! Anyway, I'm redoing it the right way. What i need to get are the dimensions to correctly place the opening as well as it's actual size. I can cut/weld/patch to make it correct. Anybody have a manual with the floorpan layout for a manual '67?
Thanks!
Shooter
Shooter is offline
post #2 of 5 (permalink) Old 06-12-2017, 01:18 PM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
Manual trans cars have a 'hump' installed over the floor. Most shade tree guys just hacked the floor. Good news is the hump is available from just about any GTO restoration supply house. Called a 'shifter porch', and BTW, console / non-console is different(?)
64GTOConvertible is offline
post #3 of 5 (permalink) Old 06-14-2017, 03:17 PM Thread Starter
Quoted: 12 Post(s)
Yup, I've seen these. Now where does it go? (inches from side/front)?
Shooter is offline
post #4 of 5 (permalink) Old 06-14-2017, 07:17 PM
Quoted: 404 Post(s)
Here are pics of my '68 Lemans - had the 3-speed manual transmission. The "shifter porch" is shaped so as to fit where it follows the contour of the driveshaft tunnel. I show the measurements just to give an idea of how it locates. Looks to be 4" from the floor rib to the front of the cover.
I included the front console bracket location if you or anyone else needs to add it. The bolts are not even, they are off set on the bracket with the left one being further down leg. Looks like it is the center slot that the console screw goes into that is actually centered. I measured off from the trans tunnel where it meets the floor and created the flat spot. The distance from that point to the front of the console bracket measured 3 inches. That should get you close enough to attach a console.
The third pick shows the location of the shift hole in the cover should you have some aftermarket cover which is not as factory. This would at least give you an idea to the shifter hole location and possibly where to cut a hole in your floor if adding a manual transmission. The factory hole cut into my floor is not pretty, so I suspect just a basic hole was hacked into the floor knowing that the shifter cover was to be sealed and placed over it along with a console.
Name:	01 1968 Shift cover.JPG
ID:	92169   Click image for larger version
Name:	02 1968 Console Bracket.JPG
ID:	92177   Click image for larger version
Name:	03 1968 Shifr cover.JPG
post #5 of 5 (permalink) Old 06-14-2017, 09:05 PM Thread Starter
Quoted: 12 Post(s)
You're my hero - thanks!
Shooter is offline
What's that little hole for? mrbill 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 12-11-2014 10:36 AM
hole Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 10 11-16-2011 12:11 AM
Hole in transmission tunnel? DaleGolds 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 13 02-25-2011 10:30 AM
Hole in my interior? baron_iv Interior Discussions 14 01-02-2007 11:43 AM
Out of the hole pageme136 2004-2006 GTO General Discussion 7 04-17-2006 02:00 PM
