Door panel emblem removal - Pontiac GTO Forum
post #1 of 5 (permalink) Old 02-26-2016, 05:49 PM Thread Starter
Luckycat's Avatar
I just got my new interior kit and am now in the process of moving the trim pieces from the old door panels to the new ones, but not really sure how to got the GTO emblem push on clips off the pegs with out breaking them...any ideas would be great help. Thanks
ID:	72505 Click image for larger version
Luckycat is offline
post #2 of 5 (permalink) Old 02-26-2016, 08:12 PM
stich's Avatar
Do you have an eye glass tool kit laying around? The flat blade screw driver in it works quite well for getting in between the slots and gently pulling up on them. Ideally, one on each side works even better. Lightly tap the clips when off with a small hammer to reshape them for installation. I mean lightly.
stich is offline
post #3 of 5 (permalink) Old 02-27-2016, 10:01 AM
have ran across a BUNCH of the potmetal posts broken off the backs of original GTO doorpanel emblems by guys trying to carefully remove them. Over the years have had a lot of GTO guys drop by wanting a nice used door panel emblem. Even had one that eyed the original swirled GTO emblems on the blue doorpanels from my '71 Judge and went to prying on it. I could have killed him!
Instead of prying the clips off, many years ago, i began carefully cutting the stamped steel clips with the thin abrasive wheel in my Dremel tool, then using new clips from Ace Hardware. the clips aren't exact but one never sees them when the doorpanels are installed.
post #4 of 5 (permalink) Old 02-27-2016, 10:25 AM Thread Starter
Luckycat's Avatar
I carefully pryed them off using 2 very small pics..then used lineman pliers to squash the clips back down..worked great, thanks guys.
Luckycat is offline
post #5 of 5 (permalink) Old 02-27-2016, 11:49 AM
Quoted: 106 Post(s)
I have used this method for years on plastic pinball parts made of unobtainium.
I would submerge the part in water while cutting off the push nuts, my local parts guy carries a selection of them so I would rather sacrifice the nut than chance breaking off a post.
Goat Roper is offline
65 GTO door panel removal waltcoleman 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 2 09-23-2012 10:10 PM
Looking for interior door panel emblem Team Valhalla 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 04-12-2012 11:22 AM
door panel removal MikeTheDiabetic Interior Discussions 3 04-19-2010 10:43 PM
Door Panel Removal Duffman6968 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 6 01-20-2009 10:53 PM
Door Panel Removal? LS2Monaro Interior Discussions 3 10-21-2008 12:59 AM
