heater cable route - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-22-2017, 03:54 PM Thread Starter
heater cable route
Hello, I hope this is the right place to ask, I have a 66 GTO without AC. I'm getting close to completing my project. I got to the heater control unit and realize I cant find a diagram on where the cable from the heater box runs to the dash unit. There is 3 cables and when I purchased the vehicle 2 years ago, it was not connected. Does anyone have a diagram or picture on how the cables are routed? Thanks in advance.
Oh also, I did a search and not really get a good answer. Do I have to take the fender off or the inner fender on the passenger side in order to install the antenna? also, how is the antenna cable route to the inside of the vehicle. I do not see a hole on the firewall for the antenna cable to route through....
steve3842 is offline
post #2 of 4 (permalink) Old 05-22-2017, 05:33 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Did you search your '66 Service Manual? ;-)
You have to remove the windshield cowl panel in order to access the routing hole above the glove-box section of the upper firewall
It is not necessary to remover fender to install antenna body onto/into fender.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 4 (permalink) Old 05-22-2017, 10:24 PM
having a service manual should be the first item on everyone's shopping list.
pontiac is offline
post #4 of 4 (permalink) Old 05-23-2017, 03:13 PM Thread Starter
thanks for the quick response...I was wondering what that hole was for.. I just plugged it up because I thought someone drilled a hole up there by the wiper well for something else.
68 Heater Cable Hook Up "Help Needed" CynicalGoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 12-15-2018 12:05 PM
Would you go this route? Goatman68 1964-1974 Tempest, Lemans & GTO General Discussion 8 08-20-2012 03:44 PM
Route 66 extended warranty? amdoverclocker Service, Maintenance and Technical Discussion 22 01-08-2012 01:54 PM
heater cable problems danthepontiacman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 09-21-2011 05:59 AM
Which route first? GimpsGTP Engine Discussions 2 04-07-2009 01:46 PM
