Interior light question - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-03-2017, 02:33 PM Thread Starter
BRL
I have a 1967 convertible. I need replacement bulbs for both the side rear courtesy lights. Everything I can find says it should be a #90 bulb but it had #68's in it. Which is the correct bulb?
Thanks in advance, Brian
BRL is offline
post #2 of 2 (permalink) Old 09-11-2017, 12:42 PM
Hear are the descrptions.
#90 Miniature Bulb Ba15d Base - 13.0 Volt .58 Amp 7.54 Watt G6 Double Contact Bayonet (Ba15D) Base, 6.0 MSCP C-6 Filament Design. 750 Average Rated Hours. 1.44" (36.58mm) Maximum Overall Length (M.O.L.). 0.75" (19.05mm) Maximum Outer Diameter (M.O.D.). 0.81" (20.57mm) Light Center Length (L.C.L.).
#68 Miniature Bulb Ba15d Base - 13.5 Volt 0.59 Amp 7.965 Watt G-6 Double Contact (DC) Bayonet (Ba15d) Base, C-2R Filament Design, 4.0 MSCP. 5,000 Average Rated Hours. 1.44" (36.58mm) Maximum Overall Length (M.O.L.), 0.75" (19.05mm) Maximum Outer Diameter (M.O.D.), 0.81" (20.57mm) Light Center Length (L.C.L.).
rwarnerjr is offline
Interior Light Relay clicking, 3 flashes then nothing... Cross Interior Discussions 1 02-16-2015 06:14 PM
Replacing interior light on 1967 A-Body convertible????? Grant1969 Service, Maintenance and Technical Discussion 0 08-07-2014 08:59 AM
Gtogrills Interior Light package Zrocket 2004-2006 GTO General Discussion 10 12-30-2009 11:22 AM
Interior dash light color? cdcdude Interior Discussions 11 11-01-2006 07:21 PM
Interior Mounted Center Stop Light b_a_betterperson 2004-2006 GTO General Discussion 4 12-30-2005 08:57 AM
