Loose interior mirror - Pontiac GTO Forum
 1Likes
  • 1 Post By geeteeohguy
post #1 of 4 (permalink) Old 09-15-2018, 06:17 PM Thread Starter
gcstone's Avatar
Okay, I know this may sound simple but I cant figure it out. My interior rear view mirror is loose and flops down all the time and I cant figure out how to keep it in place. It is not loose at the ball, but where the mirror screws into the bracket. Any tips?
gcstone is offline
post #2 of 4 (permalink) Old 09-16-2018, 06:35 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Might try a couple of small plastic washers on each side of the bracket groove or thread locker.
Likely been over tightened one two many times and the threads are worn.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 4 (permalink) Old 12-26-2018, 08:36 PM
Quoted: 98 Post(s)
Your '67 has the first year for the safety 'break away' mirror, which has a plastic joint inside that breaks if you hit it with your head in an accident. Decades later, the plastic becomes brittle and any slight bump will break it, and render the mirror a limp noodle. My cure 35 years ago was to install an all steel mirror out of a '65 in my own '67. I installed all steel 1965-66 window cranks and door handles, too, as I got tired of the plastic knobs falling off. Dangerous? Perhaps. Functional? Absolutely!! They do make reproduction '67 mirrors, I think. I would still go with a good used or reproduction '65-'66 mirror, though, if you want it to be the last time you replace it.
1968gto421 likes this.
post #4 of 4 (permalink) Old 12-27-2018, 05:18 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
safety 'break away' mirror??
Not sure I've ever heard of this, Where would I find info?
Have to '67's at shop Conv't & HT both have no plastic on the rear view mirrors.
Thx.
Wing mirror-head loose - 68 GTO NZ-GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 08-29-2017 12:29 PM
side mirror loose SSnakeAce 1964-1974 Tempest, Lemans & GTO General Discussion 5 03-12-2016 07:33 AM
To Mirror or not to Mirror, that is the question. Getyourgoat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 11 07-10-2015 10:20 PM
Loose Suspension? GM Kid Service, Maintenance and Technical Discussion 4 07-22-2005 03:37 PM
05 SAP front fascia coming loose concerns? dms 2004-2006 GTO General Discussion 10 06-27-2005 11:29 PM
