Mystery hole on floor below convertible piston - Pontiac GTO Forum
post #1 of 6 (permalink) Old 01-15-2018, 08:42 PM Thread Starter
Quoted: 126 Post(s)
I am preparing my convertible for paint and have found a hold in the rear floor below the convertible piston. The hole is rather large and on both sides (left and right), so it appears to be intentional. That said, it will allow water and dirt (as well as rodents) to easily enter the car.
Should there be a plug in these? Are they for drainage ? Thanks
Chris
Name:	hole below convertible piston.jpg
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #2 of 6 (permalink) Old 01-15-2018, 10:16 PM
Quoted: 347 Post(s)
Chris
My guess is that it is a drain for any hydraulic fluid that might leak from the cylinders.
post #3 of 6 (permalink) Old 01-16-2018, 04:51 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
I think it would be a dual purpose, IIRC the pinchweld gutter is set up to direct water to those points as well.
I don't recall plugs but there likely should be.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #4 of 6 (permalink) Old 01-16-2018, 08:36 AM Thread Starter
Quoted: 126 Post(s)
Thanks guys! Any idea what book might have detailed information on the purposes and whether there should be a rubber drain plug ? Thanks
-- Chris
Current setup:
4 speed Muncie
cij911 is offline
post #5 of 6 (permalink) Old 01-16-2018, 07:18 PM
integrity6987's Avatar
Quoted: 44 Post(s)
slightly different - but maybe helpful?
I almost hesitated to post because It's not the same - but a few years later model. My thinking was that design solutions don't evolve that quickly unless the design is poor. Let's all agree the 65 is a great design. So my assumption is that what is design used my car is similar to the 65. I've been more active on this forum this winter - trying to learn like lots of us.
So I looked at photos taken early in the resto of my '68 - 24267. Mine does not have any tray shaped stampings as shown in your post. However, there ARE 4 plugged holes in the floor in the cabin side of the rear bulkhead. They are more or less equally spaced laterally along the transition of the flat floor and curved floor over the rear axle. They are light colored whiteish or cream colored and have been sealed (grey caulk) around the inside where the plug protrudes into the cabin space.
These would be under the seat - and clearly would not be left open to the elements from the factory.
I think these through holes should be plugged.
HTH
DK
integrity6987 is offline
post #6 of 6 (permalink) Old 01-16-2018, 09:39 PM Thread Starter
Quoted: 126 Post(s)
HTH
Thanks!
Current setup:
4 speed Muncie
cij911 is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
greg69gto
Correct Transmission Hole in Floor? Shooter 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 06-14-2017 08:05 PM
questions about steering column, wiring, and mystery hole. virginiavenom 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 11-20-2011 12:55 AM
Help diagnose mystery dash hole cgseaman 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 08-28-2010 09:34 PM
Baer 11" 2-piston discs vs. stock single piston Jeff's Classics 1964-1974 Tempest, Lemans & GTO General Discussion 8 06-29-2010 07:27 PM
Mystery engine in '66 GTO convertible Exit32 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 17 04-01-2009 11:21 AM
