Need guidance - Pontiac GTO Forum
post #1 of 7 (permalink) Old 08-18-2016, 11:59 AM Thread Starter
GtoWayner68's Avatar
Need guidance
I'm sure it's been covered before. However spending the better part of this morning using the search feature I have failed to figure out what I'm looking for. Maybe I don't know the correct terminology or part name but I can't find it through Google or I can't find it through our forum. What is the part called that covers my pillars in between the front door windows and the rear windows... see picture for what I'm asking.
GtoWayner68 is offline
post #2 of 7 (permalink) Old 08-18-2016, 02:10 PM
pjw1967's Avatar
Do a search for inner b pillar moldings....
pjw1967 is offline
post #3 of 7 (permalink) Old 08-18-2016, 02:22 PM Thread Starter
Thanks! Really appreciate it
post #4 of 7 (permalink) Old 08-18-2016, 03:27 PM
Wayne, Your '68 Pontiac Tempest or LeMans is a 2 door Coupe/aka/ 2door Post...has a frame around the door. This specific inner pillar trim piece was only used on '68-72 GM A body Coupes & is not reproduced.
-Pontiac built A body 2door Coupes through '72 model year.
-Buick & Olds discontinued their Abody 2door Post body style after the '70 models.
-Chevy built two door Post base Chevelles through the '69 models.
Not that easy to find of a trim piece. Have owned quite a few '69-72 2door Coupes over the years, & have pulled a bunch of 2 door Post trim. These same trim pieces needed replacing in my '72 LeMans Coupe (1 of 27 400 stick LeMans Coupes). I ended up pulling a pair for its restoration in MN.
Can't find these trim pieces, ck back this Fall, will be again on long roadtrlp hitting monster oldschool yards.
post #5 of 7 (permalink) Old 08-18-2016, 05:03 PM Thread Starter
Any ideas on what I could use for my gto? I do realize that this was a 2d post... but I thought maybe I didn't know correct terminology, to locate them...Iv spent more hrs searching for mother******** then sleeping and keep finding the "A" pillar trims. Do you think I could modify the a pillar trims to work?
post #6 of 7 (permalink) Old 08-23-2016, 05:37 PM
chuckha62's Avatar
Quoted: 18 Post(s)
I would expand my search if I were you. Try looking for parts (probably used) for other A body GM cars, Buick Skylark, Chevrolet Chevelle, Olds Cutlass, etc. Any of those coupes should be the same. As far as color, you can always paint/dye them black.
chuckha62 is offline
post #7 of 7 (permalink) Old 08-30-2016, 12:07 AM Thread Starter
Thanks guys. These must be hard finds. I'm coming up with Jack diddly. However I find repos for novas... Can anybody give me dementions on the b pillar trims?
Proper Alignment Specs and guidance on 66 GTO AJFrechette 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 09-24-2018 04:19 PM
My 1971 project dilemma, any advice, guidance, council, a good therapist? SpeedSLC 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 10 09-15-2015 12:26 PM
2004 Radiator Guidance!!! GTO88 Service, Maintenance and Technical Discussion 33 06-28-2015 09:22 AM
Need Guidance: '68 GTO Resto-Mod 1968 GTO Resto-Mod 1964-1974 Tempest, Lemans & GTO General Discussion 13 12-27-2012 10:51 AM
New to the forum and requesting guidance... 1967bluegto 1964-1974 Tempest, Lemans & GTO General Discussion 5 09-28-2008 04:39 PM
