Need vendor for window glass rubber 1965 - Pontiac GTO Forum
post #1 of 2 (permalink) Old 11-10-2015, 09:07 PM Thread Starter
Hello GTO fans. I should begin by saying that my car is a 1965 Skylark. The Skylark forum did not respond to my post, and I figured there were more GTO cars being restored than 65 Skylarks, so here I am needing help from you guys.
I need window rubber for the bottom of my windows. The specific pieces I need hold the bottom of the window glass into the bottom u-channel. The piece would cradle the glass into the u-channel, and it has a flap that seals against the outer rubber weatherstripping at the top of the doors.
I found the window fuzzies and the exterior weatherstripping, and I found the window channel for the door frames and post, but the rubber I can't find holds the glass in the u-channel that the regulator attaches to.
Steele Rubber does not seem to have the right stuff (at least I could not see a good match), so any help from you GM A-body experts will be much appreciated.
Rich in Tampa
scoopyg is offline
post #2 of 2 (permalink) Old 11-11-2015, 08:33 AM
SANDU002's Avatar
Have you tried OPGI.org or thepartsplaceinc.com
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
1965 GTO Vent Window - Setting the Glass Chips 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 03-06-2013 08:48 PM
65 GTO door glass mounting rubber seal hitekcm 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 12-25-2011 04:12 PM
window vendor xcmac26 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 6 01-10-2011 04:43 PM
window rubber tomstoyflyer 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 6 08-31-2010 01:57 AM
