Replacing Convertible Pump Tubing with metal lines - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-21-2016, 05:20 PM Thread Starter
Since my old Vinyl tubing is a bit leaky, I was considering replacing the existing lines with Metal Brake Lines. Has anyone done this? Is there a case to be made For or Against using Metal Lines?
Thank YOu
archlab is offline
post #2 of 2 (permalink) Old 03-21-2016, 05:24 PM
If the rams move or pivot at all I would expect the metal lines to break, crack after some time.
Replacing Brake lines ROGTO67 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 02-25-2013 08:58 AM
1967 replacing metal under rear window Help? Groundczero 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 01-04-2013 05:22 PM
replacing sheet metal in the trunk 1967 gto 67chivo 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 07-19-2011 09:53 PM
65 GTO Convertible Top pump fluid lines olde-goat 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 03-27-2011 09:41 AM
metal brake lines Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 10-31-2010 08:43 PM
