Replacing Window Felt and Weatherstipping - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-01-2018, 09:15 AM Thread Starter
Quoted: 4 Post(s)
Hello
We own a 68 GTO Convertible and want to replace the felts and weatherstripping around the 4 windows and 2 vents. If anyone has done this before, could you let me know the level of difficulty, if there are any special tools necessary or advantageous, etc. I'm trying to determine if I should attempt to do the work myself, or have a restoration shop do it. Thanks, Mike
mwatson1647 is offline
post #2 of 4 (permalink) Old 08-01-2018, 01:49 PM
Quoted: 78 Post(s)
Are you comfortable removing the door panels and glass? If so, the rest is fairly easy. The vent window frames come apart easy. 2 screws visible at the bottom and one semi-hidden screw at the upper corner. The vent window weatherstrip is held in place with clips so will need to remove them from your old rubber and reuse them.
There is a good tutorial on the Danchuck website for vent window rebuild. Its specific to Tri-Fives but the process is about the same.
Unless you have NOS felts....the replacements won't look exactly like your originals. They will fit and function the same....but the stainless will appear different visually and there won't be a rubber flap on the paint side.
As far as I can tell, there are no reproduction felts for 68 that are exactly like the originals.
Shake-N-Bake is offline
post #3 of 4 (permalink) Old 08-02-2018, 07:57 AM Thread Starter
Quoted: 4 Post(s)
Thanks Shake-N-Bake! My biggest concern is getting the door panels off without causing any damage. Once those are off, then I think by seeing the works inside I'll be able to tell how to go from there, but not sure where best to start prying the door panels. I'll look at the Danchuck website as you suggested. Thanks again, Mike
post #4 of 4 (permalink) Old 08-02-2018, 12:49 PM
Quoted: 78 Post(s)
The Fisher Body manual will have all the info you need for door panel and glass removal. You can download it here:
http://thefirstgensite.com/html/68fisherbody.htm
"68" Front Window felt length Layzdude 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 0 01-06-2016 12:08 PM
window felt morris66 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 02-22-2011 11:06 PM
Still Felt Good oldgoat Racing and Kill Forum 9 06-18-2007 02:17 PM
I felt like a child.... mlekawa Racing and Kill Forum 8 05-31-2007 01:40 AM
Felt Like Playing Poker With Children Red Bearded Goat Racing and Kill Forum 1 05-17-2007 08:32 PM
