Seatbelt bolts - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-23-2016, 07:05 PM Thread Starter
Seatbelt bolts
Hello, I just have my floorboard on my 66 GTO replaced. I cant figured out how the front bucket seats are bolted down. Does it go through the floorboard and the bracket before bolting through the seat? Also does the front seatbelts share the same bolt as the seat bolt or does it have its own bolt that also go through the floor...any pics would be appreciated.
steve3842 is offline
post #2 of 4 (permalink) Old 09-23-2016, 07:40 PM
GTOJUNIOR's Avatar
Quoted: 68 Post(s)
Steve,
You will need to install the mounting plates for the seats if your pan does not have them already.
Seat belts mount outboard on the rocker and inboard the tunnel independent of seat mounting with
larger bolts and require anchor plates.
Best to find a '66 to record locations to be sure you set them up correctly.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 4 (permalink) Old 09-24-2016, 11:34 PM Thread Starter
GTOJUNIOR, thanks for the reply, one more question, the mounting plates only have 3 bolts, does the last one just go through the floor?
post #4 of 4 (permalink) Old 09-25-2016, 06:50 AM
GTOJUNIOR's Avatar
Quoted: 68 Post(s)
Yes the out board rear is a bolt.
Even thought these brackets are not exactly as OE they will work.
Here is a link to an install, should give you some good insight to the task;
Install AMD 1966-1972 Chevelle Bucket Seat Brackets - Super Chevy
Best of luck.
Seatbelt extender Mathew Sokos 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 5 09-18-2016 05:00 PM
Seatbelt Layout Pics 69-er Interior Discussions 0 02-08-2011 09:10 AM
Seatbelt jamming xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 1 01-25-2010 04:02 PM
66 seatbelt question chevyboy91188 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 11-23-2009 04:26 PM
Seatbelt question blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-09-2008 10:34 AM
