steering wheel removal on GTO 65 - Pontiac GTO Forum
post #1 of 8 (permalink) Old 06-23-2017, 11:20 AM Thread Starter
ERIC60's Avatar
Quoted: 4 Post(s)
I try to remove my steering wheel in order to access to turn light switch but it seems completely blocked!
I have the special tool with two side screws plus the big center one to pull out the steering wheel but whel I turn the wrench clocwise in order to lift the steering wheel,
nothing move! is there a circlip to remove first but I don't see anyone;
it seems simply welded with the rust onto the column!
should I insist with an extension or did I miss something?
thanks for feedback;
ERIC60 is offline
post #2 of 8 (permalink) Old 06-23-2017, 11:23 AM
Quoted: 106 Post(s)
Once you have tightened the puller smack the shaft on the puller with a hammer.
A few good blows and the wheel should pop loose.
Mark the wheel and shaft with a sharpie so you can put it back in the proper position when re assembling.
Goat Roper is offline
post #3 of 8 (permalink) Old 06-23-2017, 11:28 AM Thread Starter
ERIC60's Avatar
Quoted: 4 Post(s)
good idea, I'll try and I'll let you know;
I'll spray as well some WD40 to help;
ERIC60 is offline
post #4 of 8 (permalink) Old 06-23-2017, 11:49 AM
Quoted: 106 Post(s)
Something like Kroil or break free will work much better than WD40.
post #5 of 8 (permalink) Old 06-23-2017, 01:59 PM Thread Starter
ERIC60's Avatar
Quoted: 4 Post(s)
in France, we have "degripoil" which is the same; I 'll buy some...
ERIC60 is offline
post #6 of 8 (permalink) Old 06-26-2017, 09:43 AM Thread Starter
ERIC60's Avatar
Quoted: 4 Post(s)
bingo! it works!
but unfortunately, I still haven't found what I was looking for!(smells like U2!)
I took off the steering wheel to access to the turn light switch and horn switch;
I don't see any wire coming out from the steering column!!!
and however, my turn lights goes well!
I really don't understand where the wire goes;
here is a picture of the column; the connector attached to the column is a "dead end", there is nothing behind;
s if you know where are these wires, any help will be really welcome!!
ERIC60 is offline
post #7 of 8 (permalink) Old 06-26-2017, 09:47 AM
Quoted: 106 Post(s)
On the bottom of the mast jacket there is a metal cover, gently squeeze it and it pops off revealing the loom.
post #8 of 8 (permalink) Old 06-26-2017, 09:53 AM Thread Starter
ERIC60's Avatar
Quoted: 4 Post(s)
you mean the one appearing on my picture with the tilting cable end?
ERIC60 is offline
1967 gto interrior steering wheel assembly / column removal help 1967gtoGeorge 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 5 09-29-2015 04:36 PM
67 Gto Steering Wheel Removal SPRAYPRODUCTS 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 14 12-14-2014 07:53 AM
Removal / Reinstall of silver steering wheel spoke covers. Help please! stephen77375 Interior Discussions 1 10-26-2011 10:28 AM
Steering wheel silver spoke covers removal/install stephen77375 Service, Maintenance and Technical Discussion 0 10-17-2011 01:59 PM
