Tach you very much! - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-25-2016, 10:05 PM Thread Starter
Tach you very much!
I'm trying to locate a tach for my 1965 GTO that I can place my original faceplate on. This would be the one in the clock position. I'm not sure if mine is broken or if I should replace the wiring first and hook up an MSD adapter, as the wire may have burnt when the pr vinous owner install an MSD switch.
Thanks!
Stanjco is offline
post #2 of 3 (permalink) Old 02-26-2016, 03:31 PM
I found a vintage Sun Super Tach II at a car show that with a couple layers of tape behind the bezel and it slips right in the clock hole with a nice firm fit.
post #3 of 3 (permalink) Old 02-29-2016, 06:28 PM
Quoted: 98 Post(s)
Pete Serio can repair/rebuild your original tach. Reproductions are also available that are a perfect match from the vendors.
tach maktope 1964-1974 Tempest, Lemans & GTO General Discussion 8 09-12-2013 05:25 PM
Bouncing tach SPCMarty 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 11-11-2012 10:45 PM
Tach Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 07-24-2012 03:58 PM
'70 Tach ees41 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 05-11-2012 05:35 PM
