Time for trunk surgery - Pontiac GTO Forum
 2Likes
  • 1 Post By PontiacJim
  • 1 Post By Fxnjetz56
post #1 of 4 (permalink) Old 09-03-2018, 06:24 PM Thread Starter
Fxnjetz56's Avatar
So, a couple of weeks ago, backed out of the garage, something didn’t sound/feel quite right. Found a left rear axle bearing shelled out. Pieces of the ball cage in the drum, and inner bearing race cracked.
Not a huge deal...but poking around under the car, decided it was time to clean/paint etc. keyword “poking”. Car had a felt mat glued in the trunk, and lo and behold found some rot beneath it.
Ordered 3 piece trunk pan from opgi. Pulled the tank and differential (might as well clean paint and rebush.
I’ve not done much light gage mig, but, well no time like the present.
Any tips/tricks?
ID:	115259   Click image for larger version
Fxnjetz56 is offline
post #2 of 4 (permalink) Old 09-03-2018, 08:09 PM
Quoted: 403 Post(s)
Any tips/tricks?
First, do a little practice on welding 2 pieces of sheet metal the same gauge as the trunk floor. It will also help you set-up the mig for your floor project.
You want to "stitch weld" as opposed to a straight line continuous bead. Heat is your enemy as it can warp metal and as it expands & contracts can move panels around and out of place. So tack your panels at a number of places so they do not move on you. Then you can "stitch weld" and move about the different panels to allow the hotter ones to cool before going back again.
Measure twice and cut once. Make sure everything fits before you weld.
Follow along on this build which should give you some good ideas: https://www.gtoforum.com/f83/restori...21/index3.html
Fxnjetz56 likes this.
post #3 of 4 (permalink) Old 09-03-2018, 10:00 PM Thread Starter
Fxnjetz56's Avatar
Thank You Jim. Yes absolutely plan on practice/experimenting before tackling. Pretty much done for car season here, so I’m in no hurry. Actually, my biggest problem is trying to keep the “might as well” syndrome in check... you know, as long as I’m here, “might as well” ..... fill in the blank...
Another part of the trunk project, is to repair the support structure for the rear package shelf... some chucklehead cut them out for some unknown reason. Found suitable donor pieces at Frank’s Pontiac parts...so, more welding...
post #4 of 4 (permalink) Old 09-09-2018, 06:45 PM Thread Starter
Fxnjetz56's Avatar
Finished removing rear control arms/shocks etc. to continue under chassis cleanup and paint. Painted diff, will be installing new brake line s from inline tube. Started cutout of rusted trunk pan above brace. I’ve got the 3 piece deal from opgi. I’m also considering replacing body mount bushings...
ID:	115371   Click image for larger version
ID:	115373   Click image for larger version
ID:	115375   Click image for larger version
ID:	115377   Click image for larger version
cij911 likes this.
Long time lurker, 1st time poster Muscle_Cars_Only Member Introductions 7 01-10-2017 03:02 PM
Ziggy's major surgery svede1212 2004-2006 GTO General Discussion 5 06-23-2014 12:24 PM
Just Got Back From Surgery! Falco21 The Lounge 12 04-12-2011 03:46 PM
Surgery: An EngineOuttaMe GTO JUDGE 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 34 01-05-2011 10:11 AM
Long time reader, First time poster. PIL SUNG! Member Introductions 1 06-11-2007 11:00 PM
