150 top speed? - Pontiac GTO Forum
post #1 of 15 (permalink) Old 09-25-2005, 09:15 PM Thread Starter
Premium Member
EEZ GOAT's Avatar
Send a message via Yahoo to EEZ GOAT
150 top speed?
i think not! i had a fellow goater riding shot gun with a video camara. i said i will take him to 140 so he can see how it feels. well my right foot magical turn to lead and it went past 145, 150, 155, 161 and i had to let go i did not look down at the DIC but he got it on video and i was there and i saw the tack and it was only at 5500 rpm and it still had more to give. man what a machine. 2005gtols2 will put it on the fourm soon. who said it top out at 150 please. i also had a 04 mustang gt try to get some but was wasted and pulled over at the gas station and he ask me what you got in that thing
EEZ GOAT is offline
post #2 of 15 (permalink) Old 09-25-2005, 09:41 PM
6QTS11OZ's Avatar
Thanks for the info. When I recently did 155 my goal was to see if there really was a limiter at 156, 158 or whatever it's supposed to be. But unfortunately I had to slow down because I was coming up on traffic. Some say there is a limiter and some say there isn't. Like you, I guess I'm gonna have to find out on my own. If I hit 165 I guess the limiter myth will be killed. At least on my car it will.
~I'm ya huckleberry~
~516rwhp/500rwtq~
6QTS11OZ is offline
post #3 of 15 (permalink) Old 09-25-2005, 10:01 PM
EEZ GOAT where in alabama do you live? I am in Millbrook
sig229 is offline
post #4 of 15 (permalink) Old 09-25-2005, 10:01 PM
i have an 05 A4,,,my limiter is at 159 (had digital speedo on) still had pull left...i believe i was in the range of 5000 rpm's
JMJ80 is offline
post #5 of 15 (permalink) Old 09-25-2005, 10:04 PM
The factory speed limiter is set to 155 MPH on a 2004 6-speed, or at least it was on mine.
Keep in mind that the "true" speed of the car is somewhat lower than the "speedo" speed, at least comparing my SLP-programmed Predator diagnostic data with the speedo reading it is.
Since I have nowhere safe on a highway to do 155 to test my speed limiter, and I wanted to see what it felt like when it would kick-in, I reprogrammed it to kick-in at 80 MPH. (SLP's Predator lets you drop it really low or set it up as high as 170, but there is no "OFF" setting [grumble] and I was afraid to try "0").
Instead of the car feeling like it just "runs out of power" or has a "restrictor plate" installed, it instead bucks VIOLENTLY when bouncing off the speed limiter. (I reset it back to stock after this).
So I think if you did hit the limiter, you'd feel it. Not a feeling I'd like at that speed.
BigNick is offline
post #6 of 15 (permalink) Old 09-26-2005, 01:41 AM
The factory speed limiter is 162 MPH according to all the magizines I have read and my own to eyes . Hold it down and when you hit 162 it will shut down.And you'll feel it.
smkdu is offline
post #7 of 15 (permalink) Old 09-26-2005, 01:47 AM
Any idea what the top speed is (without governor) on an 2005 with a six speed?
rippinbyu is offline
post #8 of 15 (permalink) Old 09-26-2005, 02:12 AM
W/O a governor you could go until you blow the motor but if I had to guess, they say the corvette goes over 177 MPH but if you ran that to the absolute max it would be 220 so I going to say 220+/- if you run it to the max and are on a somewhat flat surface.
smkdu is offline
post #9 of 15 (permalink) Old 09-26-2005, 02:33 AM
Well that is theoretical... so if you were in a vacuum with a constant supply of air to the engine you could hit 220ish. But in reality, I can't imagine getting over 170 in a GTO... and with the shape of the GTO, I'll bet there is alot of lift up there. But from what I hear it is alot better than F-bodies. F-bodies have windows flexing out at over 150 I've heard. Aerodynamics are crazy.
slonlo_350 is offline
post #10 of 15 (permalink) Old 09-26-2005, 07:54 AM
220mph with what gearing?
GOTPWR is offline
  Pontiac GTO Forum > Off Topic Discussions > Racing and Kill Forum
