bad night @ the strip - Pontiac GTO Forum
post #1 of 8 (permalink) Old 01-26-2011, 11:48 PM Thread Starter
Zdeuce4's Avatar
Send a message via AIM to Zdeuce4
best of [email protected] 104
under wot 3rd gear feels like it has a plate.
my car is a 46k 05 m6. clutch holds fine, but 3rd gear just does not want to go in. i have to do it slowly and then pop it in. i hate it. friend of mine said if i swap the master cylinder and the shifter out ill get a butter smooth transition. anyone that can verify this?
im not a pro driver but im decent.. my last car had an aftermarket clutch and a sts, so i was very good with it, but this is my first rwd car and i had a very tough time.. launching got a bit easier but not being able to get in 3rd all night made it a tough night.
i also noticed that that clutch fluid was under the min line as well. my last car got it directly from the brake fluid so i never had to worry about that. needless to say, im not going to the track again without my next mods that im ordering this weekend
clutch, shifter,pacesetter lts, and a master cylinder.
I do Work
Zdeuce4 is offline
post #2 of 8 (permalink) Old 01-27-2011, 10:56 AM
Completely normal. You need a GMM Ripshifter. Happens to me 2 out of three runs. They actually advertise that you will "never miss 3rd gear again".
I now have 20k on mine and it has done that since new.
mikes06goat is offline
post #3 of 8 (permalink) Old 01-27-2011, 02:06 PM Thread Starter
Zdeuce4's Avatar
i was looking at the mgw on ls1gto.. idc what i get as long as it works.
I do Work
Zdeuce4 is offline
post #4 of 8 (permalink) Old 01-27-2011, 04:03 PM
Yeah just stay away from the B&M and Hurst shifters.
post #5 of 8 (permalink) Old 01-27-2011, 10:39 PM Thread Starter
Zdeuce4's Avatar
crap does anything that they make for these cars actually work?
I do Work
Zdeuce4 is offline
post #6 of 8 (permalink) Old 01-27-2011, 11:44 PM
fergyflyer's Avatar
I had a B&M on mine and had issues. It shifted great, but the bolts that held it in place kept coming loose.
Never heard anything bad about GMM. That's the shifter to get.
GTO is a great car. Not sure why you'd ask if anything works. Also remeber you're not dealing with a car that has 150-200 lb ft of torque too. With the power and torque the car makes, coupled with the weight of it, it takes substantial pieces to hold up to drag racing.
Also didn't help that you didn't check the clutch fluid. At 6 years old you should have changed every fluid in the car when you bought it. I know when I buy a used car that's the first thing I do. Brake fluid every 3 years, clutch every 3 years and rear end every 3 years. Coolant 5 years max, power steering fluid 5 years max. Fluids are the life blood of the vehicle.
fergyflyer is offline
post #7 of 8 (permalink) Old 01-28-2011, 12:28 AM Thread Starter
Zdeuce4's Avatar
bought it from carmax. they do a really good check usually. and since i didnt know the clutch had a separate fluid fill i didnt think to look until i got weird issues at the track. needless to say, when i get the clutch and headers installed ill have the chance to get the stuff done. ill be doing brake fluid when i get a new rotor and brake setup so thats next. hopefully by 50k ill have everything changed including plugs.
I do Work
Zdeuce4 is offline
post #8 of 8 (permalink) Old 01-28-2011, 12:35 AM Thread Starter
Zdeuce4's Avatar
my last car had about 300whp and 300whp. i had a turbo cobalt.
its just a bit nerve racking when looking at parts for the gto and there's so many failure rates.. b&ms no good, hurst's going limp
b&m and hurst are pretty much top of the line for cobalts in the shifter department.the vendors for them dont sell parts that fail as often as ive seen for these two companies on gto shifters. if there is an issue like that the people dont buy the products anymore.
i dont mind spending the cash. i just want to do it once and be done with it.
I do Work
Zdeuce4 is offline
  Pontiac GTO Forum > Off Topic Discussions > Racing and Kill Forum
This is why streaking @ night is bad 6QTS11OZ Audio & Video Clips 1 01-14-2011 02:56 PM
Finding bad bad vibrations [email protected] 1964-1974 Tempest, Lemans & GTO General Discussion 11 11-25-2008 10:38 AM
It was break your car night last night fergyflyer Racing and Kill Forum 8 09-08-2007 09:28 PM
bad night at the track squrtdog50 Racing and Kill Forum 0 05-24-2007 05:00 PM
Keep it at the Strip bluhaven The Lounge 8 09-22-2006 07:14 PM
