First Drag Times in my new GTO - Pontiac GTO Forum
post #1 of 12 (permalink) Old 11-14-2009, 11:47 AM Thread Starter
InfinityExperience's Avatar
Purchased a 2006 GTO M6 about a month ago and decided to take it to the strip for the first time with some friends. I've never been to a drag event before so I had a damn good time just spectating let alone getting on the line. Had the jitters for the first run (see below) but after that it would have taken a bulldozer to remove the smile off my face.
Passes made on street tires, quick spin of the wheels before staging, attempted to launch from about 2200 rpm but I dunno how well I accomplished that. I'm running Kooks LTs, high flow cats, AEM intake and a GMM short throw.
First run: Since I kept turning the car on and off moving through the line, when I finally pulled onto the line I forgot to turn off traction control So many things going on in my head for the first run it figures I'd look over something simple. On the positive side, it was my best reaction time out of the three runs (0.626) and strangely enough my fastest overall speed (105.86mph).
Second run: Spun bad off the line and significant wheel hop in second, decent shifts through the pull. Still managed to crush the soul of a GT mustang with a few bolt-ons.
Third Run: Terrible reaction time (1.039s) Had my mind focused on keeping traction off the line, pulled pretty well but had a garbage shift into third. Still pretty happy as this run gave me my best time.
Even with the differences in R/T; take off error; and shifting issues all my runs had almost the same exact top speed (105.86, 105.31, 105.77) Are these wheel spin issues? Considering the first run was my fastest and had traction control on...
First, Second, and Third runs listed in order.
InfinityExperience is offline
post #2 of 12 (permalink) Old 11-14-2009, 05:22 PM
IE,
I have no doubt with a few more runs under your belt, and after reading a few tips from some of the more experienced guys here, you will be in the 2.0s in your short, and in the 87 mph range in the 1/8, which should equate to near 110/13.0. I assume you have a tune, either handheld or dyno?
I went to Baytown last Friday after work in mine and turned the best times/speed ever. I was running mainly in the 13.6 to 13.8 range, installed a CAI and a diablosport tune and got into the 13.1s. That is why I say with the LTs, you should do well. It is now in your hands, practice that launch, the rest is history.
shiftR is offline
post #3 of 12 (permalink) Old 11-15-2009, 02:45 PM Thread Starter
I had a feeling the car may have been tuned prior to my ownership! Thank you for confirming my suspicions. The only downside is that with the addition of the catback I'm looking for, there aren't too many more bolt-on upgrades to go for.
My research has pointed out larger TB, MAF, fuel injectors or TB spacers aren't really necessary without a forced induction set up or cam which are not going to happen for me anytime in the next few years. I have heard the same for most of the porting jobs finished by members, (intake manifold, heads). Maybe everything together shows noticeable gains but not by themselves is what I'm saying.
I'm thinking 275s in the back could be a worth while investment, maybe the BMR subframe connectors for some added rigidity in cornering (I like to keep my speed up when heading on or off the freeway, can definitely feel the body roll).
post #4 of 12 (permalink) Old 11-18-2009, 06:30 PM
It's a lot of fun, isn't it? Strive for 2.0 60fts at a minimum. It's not just technique but knowing what tire psi to run as well. The stiff sidewall performance tires "may" give better 60fts if the psi is in the mid-30s (this is the case for the 20" F1 Supercars).
I've done the off/on cycling as well, pushing the car, etc. A lower temp thermostat usually helps if it applies to the LS2. Will the tuner allow to adjust for the cooling fans to come on sooner?
'07 Audi A4 2.0T Quattro "commuter"
'09 G37 Coupe Journey
'11 HD Street Glide 103
“The Andy Rooney of Cars”
Examiner.com
“My automotive consultant.” - Wayland Joe, 2-time SCCA Runoff Champion, exotic car owner
Deuuuce is offline
post #5 of 12 (permalink) Old 11-24-2009, 01:02 PM
The Detailer's Avatar
Set of drag radials would help with the 60'.
05 GTO/A4 Just some bolt ins 1.7461 60' 4.9649 330' 7.1500 594' 7.6440 1/8 mi. @ 91.10 mph.
The Detailer is offline
post #6 of 12 (permalink) Old 11-24-2009, 01:44 PM
GTOAA 04-06 Technical Advisor
GTOJer's Avatar
For your 3 times down the track you are doing GREAT! You can see all of the times getting better each run. Right now just keep practicing. Try not to make too many changes to your car and keep working on it. Drag radials can come later as well as a bunch of other stuff.
I would recommend you keep a log of each run and comments. Do it at the track because you will not remember when you get home. Welcome to the world of drag racing.
Now I have been drag racing for many years. I have a mountain of passes under my belt, something close to 1000. I used to campaign a KZ1000 in Jr Pro Stock and then a ZX-750 Turbo in C-Stock Turbo back when NMRA was still in business. I was the speed record holder in that class. Never could get the time. I even raced the time record holder a few times. I have had my current GTO down the track 72 times. Here is what I have found works best for me. I launch the same as I did on street tires, 3,000rpm and a fast slip, not a dump. Here is my best when stock:
(RT/60'/330'/8th time/8th speed/1000'/end time/end speed)
0.137 2.009 5.706 8.722 81.91 11.314 13.512 102.65
and after a few mods
0.014 1.680 4.906 7.468 97.84 9.566 11.419 123.62
Jerry
GTOAA '04-'06 Technical Advisor
My Shop
KPE - Klaus Performance Engineering
2004 Pontiac GTO 6.7/M6/Barbados Blue (1 of 271) My Car Page
Featured in the April 2007 High Performance Pontiac Magazine
GTOJer is offline
post #7 of 12 (permalink) Old 11-30-2009, 07:20 PM
Holy smokes, GTOJer!
A "FEW" mods. Please tell me what I have to do to get those times!!
Is your car a daily driver, or close?
shiftR is offline
post #8 of 12 (permalink) Old 12-02-2009, 10:40 AM
KyleGT05usmc's Avatar
decent times, like you - my first runs i kept leaving TC on as well, i got to a [email protected] first day of racing my GTO (NC low elevation)
you have intake/exhaust opened up pretty good, if im not mistaken i doubt your stock pcm settings are giving you enough fuel now, i'd suggest a tune and you might see some improvement in the traps.
i read an article where a wrx had intake installed then separately exhaust installed, both made about equal gains(say 15hp), but once they installed both together, it made less gains than just 1 of either exh/int(~8hp) until they tuned it then it made about double gains(~25), as to be expected. now i know our cars arent wrx's but i think a tune would definitely help you out. anyone else have a little more knowledge about this?
just my .02
good times. keep it up
K&N CAI, lightly ported stock TB/INT, JBA Hpipe, Spintech Side Exh. ([email protected] r/t .8800 60' 2.06)
1/13/10- Kooks 1 3/4, LS7 Clutch, B&M shifter
1/21/11 - Eibach Springs, Monroe Shocks, EBC Brakes
Soon - "Sungold" PowderCoated 17"s
KyleGT05usmc is offline
post #9 of 12 (permalink) Old 12-02-2009, 01:33 PM
slow ass times.....get some mt et streets they will help alot
acrespo1986 is offline
post #10 of 12 (permalink) Old 12-03-2009, 12:35 PM
Did you get your block resleeved, or are you running a crank over 4"?
Poncho Dan is offline
  Pontiac GTO Forum > Off Topic Discussions > Racing and Kill Forum
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Definitive Definition Of Gto Suspension Concerns dms Drive train, suspension, alignment and brakes. 1 12-05-2008 12:47 AM
My Dealership Experience Today in_burrito 2004-2006 GTO General Discussion 43 12-20-2005 05:14 PM
