Got Wheelhop? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 12-13-2005, 12:50 PM
big_mike
Guest
Posts: n/a
Quoted: Post(s)
Got Wheelhop?
For those with an 04, you can get a set of polyurethane bushings for the rearend (at the point where the IRS attaches to the body). These bushings GREATLY reduce some of the wheelhop culprit common in the 04 models.
Some of the items offered by Energy Suspension are below:
Year - 2004
Front End Control Arm Bushing Set - 3.3187
Rear End Control Arm Bushing Set - 3.3188
Front Sway Bar Endlink Set - 9.8161
Front Sway Bar Bushing Set - 28mm - 3.5210
Complete Rear Sway Bar Bushing Set - 20mm - 3.5211
Rear Sub-Frame Bushing Set (street firm) - 3.4125 (126)
Rear Sub-Frame Bushing Set (race firm) - 3.4164 (127)
OR, you can get the complete package.
HYPER-FLEX SYSTEM Complete Master Bushing Set Includes: Front control arm bushings, rear control arm bushings, front sway bar bushings, complete rear sway bar bushing set, rear sub-frame bushing set (street firm).
Part No.: 3.18134 (126)
How much for these parts? Well, the rear subframe bushing set, which controls a portion of the wheelhop, is $96!!!
post #2 of 7 (permalink) Old 12-13-2005, 01:57 PM
johnebgoode's Avatar
and they're graphite impregnated to eliminate squeaks.....!!! All those parts are good for the '05 also.
johnebgoode is offline
post #3 of 7 (permalink) Old 12-13-2005, 01:58 PM
They will help wheel hop, but if your GTO is an everyday driver, I would not recommend them. I replaced all the rubber bushings in my '02 GT with polyurethane ones and while the handling characteristics improved, the the ride was rough and they were noisy, especially in colder weather.
QwkRed05GTO is offline
post #4 of 7 (permalink) Old 12-13-2005, 01:59 PM
That solves the biggest issue I had with the poly parts I mentioned above
post #5 of 7 (permalink) Old 12-13-2005, 02:00 PM
Allegedly the graphite is supposed to help the noise. As far as everyday driving, I'm going to take the chance and see how it is. Only doin the rear sub frame bushings.
post #6 of 7 (permalink) Old 12-14-2005, 08:50 PM
I have poly subframe bushings. I could tell the ride was a little stiffer but I don't notice it now.
2005Goat is offline
post #7 of 7 (permalink) Old 12-15-2005, 12:13 AM
Vedli
Guest
Posts: n/a
Quoted: Post(s)
U guys really hear the noise of your car? .. gah all I hear is my motor screaming and my sounds .. LMAO... "im going def"
  Pontiac GTO Forum > Off Topic Discussions > Racing and Kill Forum
