Launch Stratedgy for the 05 A4-Drags - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-18-2005, 11:39 PM Thread Starter
Has anyone had a chance to practice launching their 04 or 05 A4 at the drags yet. Looking for a good technique.
I was wondering if you could launch with traction control on and once you were rolling hit the button and disable it.
I am planning to try rolling out 1/4 pedal and nailing it but I was wondering if the T/C might just work as a launch tool.
bogie1 is offline
post #2 of 6 (permalink) Old 02-19-2005, 03:17 PM
ramairws6
Guest
Posts: n/a
Quoted: Post(s)
auto or 6 speed?
post #3 of 6 (permalink) Old 02-19-2005, 03:52 PM
Originally Posted by ramairws6
auto or 6 speed?
A4 means 4 speed auto.
I'd try stalling just above idle and eaaasing into the throttle - taking about 1 full second to reach full throttle.
97GTP is offline
post #4 of 6 (permalink) Old 03-11-2005, 10:32 PM
97gtp, how do you handle your gtp out of the hole?
I am the pround new owner of an 05 a4 GTO, pedal to the metal in one sec seems a bit too much, any other opinions out there?
Or am I just being a nancyboy?
StocktonRaider is offline
post #5 of 6 (permalink) Old 03-11-2005, 11:09 PM
I would suggest get out there and practice launching at different rpm's so that you can learn your car and your area (different temperatures and elevations will also come into play). I have to launch close to idle otherwise I just spin too much. I would assume that you could launch with the T/C on and then disable it down the strip but, I would also assume that after the initial launch leaving the T/C on for the rest won't matter much. I know there's a lot of assuming going on here but, then that leads me back to get out there and see what happens to your car (just make sure your in a secluded area so you don't have to worry about the cops being called).
IPOCKALYPSE is offline
post #6 of 6 (permalink) Old 03-12-2005, 02:07 AM
btchplz's Avatar
'05 Launch
ANy suggestions on a M6 as far as RPM's go? With or without T/C?
btchplz is offline
  Pontiac GTO Forum > Off Topic Discussions > Racing and Kill Forum
