Raced last night - results - Pontiac GTO Forum
post #1 of 10 (permalink) Old 10-11-2008, 05:23 PM Thread Starter
forensicsteve's Avatar
First time in 3 months. Little cooler than in July but still quite humid. Used a 50 shot of nitrous on first run only...didn't work well. So didn't use it again. Best run was 10.4 @ 130 (no nitrous). Don't have video of the 10.4 pass, but plenty at 10.5.
Having car retuned Oct 24...datalogging showed degrees of timing down to 10at the end of the run. Also going to increase boost from 20 to 25 lbs or until the intake manifold blows (will bring a spare)
npr101008.flv - Video - Photobucket - Video and Image Hosting
06GT, 76mm turbo @ 22 lbs boost, stroker built motor, 4r70w, alcohol inj sys
old times before recent engine rebuild and new power mods
10.0 @ 136
forensicsteve is offline
post #2 of 10 (permalink) Old 10-11-2008, 05:31 PM
PDQ GTO's Avatar
Hard core for sure Steve!!! Going to need a wheelie bar soon…willy:
PDQ GTO is offline
post #3 of 10 (permalink) Old 10-12-2008, 11:27 AM
Those are awesome times!!
What should your timing be at the finish line?? Are you still on the spray going across the line @ 10at? Or is that just from the boost it(your MSD box I would assume) retards it that far??
post #4 of 10 (permalink) Old 10-12-2008, 01:14 PM Thread Starter
All the 10.5 runs were without nitrous. In fact, we are not going to use nitrous anymore. It's been too erratic and we're into bracket racing where 1/100s can often make or break.
Also changing tuners. Last tuner was very good for street tunes on pump gas but we need a place that is used to 1000+ hp cars on C16. Scheduled for such a racecar tune end of this month. Expect timing to come down at the big end, but timing was at 18 to start the run. Should be closer to 30 on the C16.
Also going to increase boost from 20 to 25 lb or as much as fuel supply will tolerate. Yes, car has MSD 2 step, transbrake, and delay box.
Thanks for the continued interest and support.
10.0 @ 136
post #5 of 10 (permalink) Old 10-12-2008, 02:51 PM
nitrous is too erratic even with the stutterbox? looks like pretty good progress. good luck with the new tuner. hopefully he/she can get you right wit 116 and nawz
koman is offline
post #6 of 10 (permalink) Old 10-13-2008, 02:31 AM
Aramz06's Avatar
Send a message via AIM to Aramz06
Whooo getting better and better... keep it up.
-LSS Shifter
-Resonator Delete
-Flowmaster 44 Series Mufflers
1 of 475
Aramz06 is offline
post #7 of 10 (permalink) Old 10-13-2008, 02:55 PM
alsgto04's Avatar
Very nice numbers.
alsgto04 is offline
post #8 of 10 (permalink) Old 10-14-2008, 02:41 PM
wow....
rrutter81 is offline
post #9 of 10 (permalink) Old 10-15-2008, 08:55 AM
I'm interested to see what a different tune does to the same equipment! The new guy might know how to get it to run on the nitrous the way it should. With 10.5s now, you could be in the 9`s with the nitrous!
post #10 of 10 (permalink) Old 10-17-2008, 10:50 AM
Nice #'s
VistaGT is offline
  Pontiac GTO Forum > Off Topic Discussions > Racing and Kill Forum
Monday Night Cruise-in at Hooter's of Lake Norman in Mooresville, NC!! 06M6TorridGTO Southeast 5 10-08-2007 04:01 AM
It was break your car night last night fergyflyer Racing and Kill Forum 8 09-08-2007 10:28 PM
raced a C5 vette BostonF4$ Racing and Kill Forum 21 07-08-2006 12:28 PM
Wed. night test and tune fergyflyer Racing and Kill Forum 5 06-17-2005 05:53 PM
