Track Run. - Pontiac GTO Forum
post #1 of 16 (permalink) Old 03-20-2009, 12:37 PM Thread Starter
KyleGT05usmc's Avatar
Track Run.
Going to the track this weekend. will be about 65-70 and sunny, almost perfect conditions, nice cool air, with enough sunlight to warm the black top.
05 m6
K&N intake
Ported TB/INT MANIFOLD
JBA midpipe
Spintech CATBAK
Dyno Tune
375/380rw
ive got regular street tires. so, going to be a challenge to stop spinning.
aiming for a [email protected] or better, which i think is easily reasonable.
anyone have some tips for launching on street tires @ track? never taken this one to the track and im sure its diff than my camaro being IRS.
ill let you guys know my times and hopefully have some video.
KyleGT05usmc is offline
post #2 of 16 (permalink) Old 03-20-2009, 01:57 PM
Drive around the water pit and do a dry burn-out to warm up the tires. With street tires the left over water will run down the treads at the starting line and you could actually take off in a puddle, so avoid the water with street tires.
post #3 of 16 (permalink) Old 03-20-2009, 10:14 PM
RJ_05GTO's Avatar
I say make sure your engine is as cool as possible so your intake temps will be low and shoot for no wheelspin and i bet you will run at least a 12.8. I held mine at about 1400rpm and launched a little over half throttle and pinned it to the floor right about when i was half past the tree and got a 2.004 60'(zero spinning, i could have pushed it a little harder) and a 13.23 1/[email protected] and my car is an automatic pretty much stock other than a predator tune and probably around 320-340rwhp?? and my mph was a little low so i probably could have gotten a better 60' and mph if i didnt baby it as much off the line.
RJ_05GTO is offline
post #4 of 16 (permalink) Old 03-21-2009, 09:44 AM Thread Starter
yea i've gotten pretty decent at launching my camaro but its got a solid axle, just not sure how the IRS is going to do on the track in the goat.
the air should be actually quite chilly, little cooler than i thought, around the 50's when i race, mayb 60s. so i'm just going to pop the hood and bring a wire to bypass my relay to leave fans on. heat shouldnt be much of a problem.
theyve also got some 100 octane i'm gonna mix in about 2gal on a 1/2 tank, i kno too much can damage o2 sens.
post #5 of 16 (permalink) Old 03-21-2009, 01:09 PM
RJ_05GTO's Avatar
yeah you dont want any timing to be pulled. When i jumped my relay(s) i had to jump the slow and the medium speed relays to get the fan to come on. It wouldnt come on with just the first(slowspeed) relay jumped, I guess it had something to do with the car already being up to temperature or something because the car was pretty warm after the 70 mile drive to the track. So make sure you make up at least two jumpers just in case.
If you spin and have trouble with wheelhop you could try some drag bags they should help keep the tires planted. I personally didnt have any trouble with wheelhop because i pedaled it off the line.
RJ_05GTO is offline
post #6 of 16 (permalink) Old 03-22-2009, 09:49 PM Thread Starter
well here's the results. and btw, turns out i never turned off my trac control... between cranking the car 400 times i forgot. explains why i couldnt get a powerful launch....
track was pretty well prep'd and the air temp was about 75, not sure track temp.
4 runs
RUN 1
R/t .9659
60' 2.08
1/8-mph [email protected]
1/4-mph [email protected]
raced a heavy modded eagle. he ran [email protected]
RUN 2
r/t .8400
60' 2.11
1/8 [email protected]
1/4 [email protected]
raced some GMC truck he was close w/ a [email protected]
RUN 3
r/t .8800
60' 2.06
raced a slowcamino, 14.8
RUN 4
r/t .8698
60' 2.08
raced a loud 5.0, and he blew somethin up 17.3(video)
well all in all, i was definatly asleep at the light, thought i was going on the last yellow but i was afraid to red light too much..gotta work on that. and with that freakin traction control i forgot to turn off i couldnt get a 60' worth a sht.
if i had at least taken the t/c off i'm sure i would have been in the high 12s. ohwell live and learn.
anyone selling a driver mod?
YouTube - GTO vs 5.0
post #7 of 16 (permalink) Old 03-23-2009, 07:06 AM
bluebeast's Avatar
Your reaction time sucks but your sixty is very good for a street tire car!!! You were on street tires and not drag radials right? Looks like a good day at the track. Nice video of the Mustang beating.
SRT-4 Stage 3
[email protected],
Best trap 120.60
Best sixty 1.68
bluebeast is offline
post #8 of 16 (permalink) Old 03-23-2009, 04:53 PM
I go to coastal frequently-
as stated, your 60' times are pretty good for street tires...
turn off t/c and you will consistently be trapping 108-110 and a couple tenths faster...
my best run @coastal with LPE intake, corsa cat back and a tune...
R........0.6858
60......2.1160
1/8.....8.5933
mph......86.02
1/4.....13.1232
mph.....108.41
Ninjured is offline
post #9 of 16 (permalink) Old 03-23-2009, 05:41 PM Thread Starter
you're from morehead, 'MHC' ?
I think i might have seen you out there on a friday night before the winter?
i was hanging out with a couple guys from SIK, a carclub based up in morehead sunday, some fast ls1s, few of them were just a couple 10ths and 2-3mph behind me.
but yea, the t/c was def slowing me down, it was really hurting my 60' cuz i could feel it bogging me down each time i just kept forgetting to turn it off.
and that freakin rev limiter. i would just stretch 3rd gear all the way but, as i did the first run i hit the limiter, so im forced to get 4th.
this next time around ill hopefully have some new tires, i have some triangle brand garbage discount tires on there now from the previous owner. and i have better feel for the car and will remember my t/c...
so hope my numbers will be a .200-.300r/t with a 1.95-1.99 60' and [email protected] if not better, the car can do it for sure, just a matter of me getting the feel down.
K&N CAI, lightly ported stock TB/INT, JBA Hpipe, Spintech Side Exh. ([email protected] r/t .8800 60' 2.06)
1/13/10- Kooks 1 3/4, LS7 Clutch, B&M shifter
1/21/11 - Eibach Springs, Monroe Shocks, EBC Brakes
Soon - "Sungold" PowderCoated 17"s
post #10 of 16 (permalink) Old 03-24-2009, 10:10 AM
Def work on that driver mod . I hope no GTO haters see your times....that is the kind of stuff they use to discredit our cars. Your Goat should be a consistent high 12's car at 110+
WanaGTO is offline
  Pontiac GTO Forum > Off Topic Discussions > Racing and Kill Forum
Great Lakes/Midwest Track Days - 2009 Feffman Great Lakes 5 07-28-2009 07:35 AM
First Track Run goatcrazy88 2004-2006 GTO General Discussion 9 12-19-2008 08:18 AM
Southeast Goats--Carolina Goat Herd Track day lisatw151 Southeast 8 10-19-2007 12:47 PM
4 Goats at track tonight/ New best but not great HTRDLNCN 2004-2006 GTO General Discussion 0 09-30-2005 11:31 PM
