Went to the track to test the 60 shot - Pontiac GTO Forum
post #1 of 15 (permalink) Old 04-23-2010, 11:27 PM Thread Starter
RJ_05GTO's Avatar
Well overall it was a ok night. Not great but i kinda expected it to go this way. I went last night to mostly have fun and to test out my 60whp dry shot. I ran seven runs. More than i usually run and i didnt let it cool off too much between runs only the amount of time i had to wait before my next run. My intake temperature was blazing hot around 140 degrees before my run and 110 or so degrees after i got down the track. My first 4 runs were n/a and my best run out of them was
R/t .147
60' 2.092
1/8 8.730
mph 83.53
1/4 13.474
mph 103.83
My first nitrous run i had it setup to spray in 1st 2nd and 3rd. My first run when the nitrous hit in first gear it smoked the tires very badly and i had to let off and back on so that run ended up a [email protected] 109.87. I set it to spray in only 2nd and 3rd gear and my next run was a little better a [email protected] and on that run i felt the car cut back a little on the big end of the track. I went back to the staging lanes and bumped my bottle heater up a little and waited for my last run and this one was my best but could have been better because my 60' was a little slower than before.
Last run best on 60 shot
R/t .165
60' 2.107
1/8 8.443
mph 88.46
1/4 12.837
mph 112.86
I know its capable of at least .2 better than im getting(with me driving) because of the heat so im not too disappointed. The 60 shot brought me down a little over 6 tenths and 9 mph over my best n/a run for the night. And also this is a after the maf setup with the harris speedworks interface so the nitrous does not cool the intake temps down so thats a bummer. I had a lot of fun!
05 GTO A4- Svede otrcai, Fast 102, Livernois stg 2 ported heads, Texas Speed 224R cam, Pacesetter LT's, Edge 3000 stall, Kooks afterburners, Pedders 0 drp rear springs and shocks, MT et streets, 418rwhp/391rwtq, [email protected]
RJ_05GTO is offline
post #2 of 15 (permalink) Old 04-24-2010, 09:59 AM
fergyflyer's Avatar
Considering the intake temps and the no cool downs, those are very decent runs. Sounds like you were very consistant in your tsting methods so you can definately expect a .6-.7 bump in performance and a huge mph difference with the Nitrous.
I guess that's why they call it laughing has, it makes you laugh with how much fun it is.
fergyflyer is offline
post #3 of 15 (permalink) Old 04-24-2010, 10:05 AM
Those are great times! What gear are you in going through the finish line?
post #4 of 15 (permalink) Old 04-24-2010, 10:28 AM Thread Starter
RJ_05GTO's Avatar
yea i wanted to get my best possible n/a run with the conditions the way they were before i tried the nitrous. I really wanted to make a few more passes with the nitrous because i felt it had a bit more in it but it was getting late and i had an hour drive back home. But loads of fun it was!! Its Just something about when that nitrous boost kicks in. It feels very nice even being only a 60 shot.
RJ_05GTO is offline
post #5 of 15 (permalink) Old 04-24-2010, 10:33 AM Thread Starter
RJ_05GTO's Avatar
Thanks Rukee! Its an A4 and its in the middle of 3rd when i cross the finish line.
RJ_05GTO is offline
post #6 of 15 (permalink) Old 04-24-2010, 12:19 PM
maybe you need a 2 stage 60-125 shot?
post #7 of 15 (permalink) Old 04-24-2010, 02:53 PM Thread Starter
RJ_05GTO's Avatar
yeah a 125 hit would be awesome!! I have everything needed to add another stage. But im running a dry setup right now and my injectors are almost maxed with the 60 shot. So before i can spray a bigger shot i will have to upgrade my fuel system. I think im going to go with a set of drag radials and maybe set a delay if needed so i can spray it in first gear and just see how far i can get with the 60 shot. I tried spraying it in first gear last night and it didnt work too well. As soon as the nitrous hit 3000rpm after i launched I did a fabulous rolling burnout!
RJ_05GTO is offline
post #8 of 15 (permalink) Old 04-24-2010, 07:55 PM
bluebeast's Avatar
The DRs should cut another 3 or 4 tenths of your time. Set the delay up to come in at 3500 and cut out at 6 grand and that should cut another 10th or so. Nice runs.
SRT-4 Stage 3
[email protected],
Best trap 120.60
Best sixty 1.68
bluebeast is offline
post #9 of 15 (permalink) Old 04-24-2010, 08:43 PM Thread Starter
RJ_05GTO's Avatar
Thanks!! Im going to definately look into a set of drag radials after i come back from vacation. I need another 18" wheel. I already have one extra that i replaced because of a little road rash that i planned on refurbishing for a future replacement.
RJ_05GTO is offline
post #10 of 15 (permalink) Old 04-25-2010, 12:44 PM
The Detailer's Avatar
Drag radials and a good stall converter, Plus a real tune and you could run those times without nitrous.
05 GTO/A4 Just some bolt ins 1.7461 60' 4.9649 330' 7.1500 594' 7.6440 1/8 mi. @ 91.10 mph.
The Detailer is offline
  Pontiac GTO Forum > Off Topic Discussions > Racing and Kill Forum
Wet shot or Dry shot sgarsh2 Engine Discussions 6 09-03-2009 01:23 PM
Almost a shot at nothing!!! deaner17 2004-2006 GTO General Discussion 2 10-15-2008 12:55 PM
Awesome video of Camaro testing on German roads and test track. Listen to that beast! 1bad350z The Lounge 7 04-25-2008 07:14 AM
First shot grapeknutz 1964-1974 Tempest, Lemans & GTO General Discussion 18 11-12-2004 01:00 PM
Second shot? Munday 1964-1974 Tempest, Lemans & GTO General Discussion 4 08-29-2004 08:45 AM
