1965 Front Brake COnversion - Pontiac GTO Forum
post #1 of 5 (permalink) Old 03-09-2006, 03:27 PM Thread Starter
I want to convert my front brakes from power drums to power discs. I have found a conversion kit that includes the spindles, rotors, calipers and a few extras (bearings, etc.).
My question is, what master cylinder should I use? I am considering switching out the stock single master for a dual master. I am assuming that I can do without a proportioning valve and just go with a dual master cylinder off of a GM car that had front discs and rear drums.
Is this assumption correct? If so, what master cylinder should I look for?
Thanks,
Ted
BajaGTO is offline
post #2 of 5 (permalink) Old 03-10-2006, 02:38 PM
I am researching doing the same thing to my 68 coupe. You do need a proportionong valve in addition to the dual master cylinder so 70% of the effort goes to the front brakes. Be careful how you do this. I suggest buying a kit with all the parts. They are readily available from a few sources. Do a Google search.
Joe
red68gto-Joe is offline
post #3 of 5 (permalink) Old 03-10-2006, 04:05 PM Thread Starter
I found a place that sells all of the parts except the master cylinder (including the proportioning valve). I was just hoping that someone on here would be able to help me out.
BajaGTO is offline
post #4 of 5 (permalink) Old 03-10-2006, 05:09 PM
Ames Performance (amesperf.com) and Direct Fit Brakes (dfbrakes.com) sell all the components that you need as a kit. Some kits have power boosters and master cylinders that look just like a Delco unit and some do not. I hope this helps.
post #5 of 5 (permalink) Old 03-11-2006, 08:10 AM
SANDU002's Avatar
I got my brake kit from stainlesssteelbrakes.com Everything I needed was there.
SANDU002 is offline
