1965 GTO Dual Master Cylinder - Pontiac GTO Forum
post #1 of 2 (permalink) Old 12-17-2018, 02:11 AM Thread Starter
I want to Convert my Single Master Cylinder to a Dual Zylinder and also change the Booster. But, i wanna stay with Drums Front and Rear.
What Products do you Guys recommend?
ManuelB is offline
post #2 of 2 (permalink) Old 12-17-2018, 07:57 AM
Quoted: 153 Post(s)
Several companies make what you are looking for CPP, Right Stuff, etc. You'll be able to fit a dual diaphragm 8" booster.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
1966 gto dual master cylinder conversion tonyli 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 04-11-2014 08:00 PM
1966 GTO Dual Master Cylinder Swap Lennox 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 07-15-2013 10:53 PM
Need advise on removing master cylinder on a 1965 GTO pftobin 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 05-10-2013 12:44 PM
'65 GTO disc brake/ master cylinder question PontiacDave 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 01-17-2011 09:25 PM
