1966 GTO tilt column - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-01-2019, 05:49 PM Thread Starter
Quoted: 4 Post(s)
Good day All and Happy March 1.
Kicking around the idea of installing a factory tilt column in the wife's '66.
The car does not have power steering (it does have a 4 speed and a factory tri-power however).
I have a couple of questions:
1) Was power steering required if a tilt column was ordered?
2) What years interchange with the '66? I realize that 1967 on up will not due to the four way flasher and later years due to the ignition switch.
3) Will other GM columns interchange? My goal is to have it look stock.
4) Is there any wiring unique to the tilt column?
5) Any other pitfalls that I am unaware of?
Thanks to all who respond.
Omni
Omni is offline
post #2 of 2 (permalink) Old 03-02-2019, 08:04 AM
Quoted: 155 Post(s)
I am about to add a tilt column to my 65' (with power steering). I am sure you could do the same with your 66' w/o power steering, you just want to measure the column length.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
69 interior colors/tilt steering column/dash components dan woodland 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 10-24-2014 11:28 AM
Non-Tilt to Tilt conversion Perry 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 10-07-2014 07:58 AM
67 Tilt Column in a 66 question Lennox 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 07-24-2013 12:22 AM
tilt column? virginiavenom 1964-1974 Tempest, Lemans & GTO General Discussion 8 11-16-2011 12:50 AM
will a 67 tilt column fit a 66? danthepontiacman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 09-26-2011 03:40 PM
