1967 Fuel Sender Unit - Pontiac GTO Forum
 1Likes
  • 1 Post By jryan4149
post #1 of 10 (permalink) Old 02-14-2018, 04:39 PM Thread Starter
The current sender has a 5/16" out feed and a 1/4" return. I tried to get this from several manufacturer's but they either had only the out feed or the fuel gauge wire connection to the unit was incorrect (current one has pin type not screw threads). I found one that matches but it's for a 1968 GTO. Looks like it will work to me. Can anyone else shed some light on this. Much appreciated.
jryan4149 is offline
post #2 of 10 (permalink) Old 02-14-2018, 07:34 PM
Quoted: 390 Post(s)
Why not step up to the 3/8" outlet and connect it to your 5/16" line. This one looks to have the pin connection and 1/4" return line - that's what I would do. https://www.opgi.com/gto/PZ00732/ Just make sure you use ethanol friendly fuel line and good quality hose clamps - double clamp the 5/16" side, remember, it is sucking from the tank and not pressurized so I would be ok doing it this way. You can also email OPGI with your question and they will answer.
post #3 of 10 (permalink) Old 02-15-2018, 03:51 AM Thread Starter
Thanks for the input. I called OPGI and that unit does not have the 1/4" return line which I prefer to keep.
post #4 of 10 (permalink) Old 02-15-2018, 09:27 AM
Quoted: 106 Post(s)
Can't you just drill a hole and add a return?
Goat Roper is offline
post #5 of 10 (permalink) Old 02-15-2018, 05:14 PM
Quoted: 12 Post(s)
I ordered a fuel sender for my 65 GTO from OPGI, which was back ordered. Two months passed and they gave me an update that it might arrive in June. I canceled and ordered one from 1A Auto and had it in three days. (It cost less too.) I'm not positive, but since my car originally came from California it had two lines; fuel and vent. Venting was a requirement in Ca. However, I don't think the vent line is essential. I sure hope not because the one I received has a single line for fuel and a pin type contact for the gauge.
NoAngelBuddy
Noangelbuddy is offline
post #6 of 10 (permalink) Old 02-16-2018, 07:50 AM Thread Starter
Thanks for the replies will try 1A Auto.
post #7 of 10 (permalink) Old 02-27-2018, 04:35 PM Thread Starter
Finally got correct unit from carparts.com. Once again thanks for all the replies.
Goat Roper likes this.
post #8 of 10 (permalink) Old 02-27-2018, 07:19 PM
Quoted: 390 Post(s)
Thanks for the follow-through. It may help someone else in the future with the same situation.
post #9 of 10 (permalink) Old 02-28-2018, 07:31 AM
Quoted: 155 Post(s)
Sorry for the dumb question, but how do these "return" setups work and is it worth adding on a 65' tri power that did not have one originally ? Also, power wise, is 3/8 really going to do anything over 5/16 ?
I know on fuel injected, high pressure lines, we like to have looped fuel rails and returns to improve flow, but I can't figure out how this would be configured on a tri power. Thanks
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #10 of 10 (permalink) Old 03-01-2018, 04:11 AM Thread Starter
The return is used for vehicles with AC. This avoids vapor lock. Only reason I got the 3/8 " is it was the original configuration and could not find the 5/16" with the configuration I wanted. '65 tri power nice.
fuel sender 65gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-23-2014 10:08 PM
1967 Lemans fuel sending unit DennyOH 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 01-09-2012 02:09 PM
fuel tank sender ground johnnylightning03 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-08-2010 09:27 PM
Question: Fuel sending unit 1967 67 Lemans John 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 03-18-2008 07:27 AM
