1967 Lemans 4 piston brake caliper question - Pontiac GTO Forum
post #1 of 7 (permalink) Old 12-12-2015, 11:28 AM Thread Starter
I recently found a 67 Lemans sprint for my brother to buy. The front 4 piston brake calipers need sleeved. I saw online that Ecklers has new ones that fit the Firebird. Are the lemans and Firebird's brake calipers the same?
Here's their link:
Firebird Four-Piston Disc Brake Caliper Assembly, Right, 1967-1968 - Eckler's Firebird Parts
Thanks.
Roycejb
roycejb is offline
post #2 of 7 (permalink) Old 12-14-2015, 09:29 AM
Welcome to the forums.
According to my NAPA PROLINK site, they are the same.
post #3 of 7 (permalink) Old 12-15-2015, 06:33 PM
You need to do the phs stuff, get the build info because if that's an original sprint car optioned with disk brakes then your car is pretty rare, a lot more rare then most gtos and cloned gtos that's for sure!
danthepontiacman is offline
post #4 of 7 (permalink) Old 12-16-2015, 02:39 PM
Quoted: 117 Post(s)
What dan said! Pretty special car, for sure.
post #5 of 7 (permalink) Old 12-16-2015, 10:20 PM
the pin spacing on the 4 piston early Bird calipers is the same for the 4 piston '67-68 A body caliper, but there is something different aboutthe original Firebird piece. It may be the angle of the casting where the boss is for the hose to attach, that's how it was for the '69 single piston calipers. Interestingly, the original Bird 4 piston calipers have larger diam caliper bores than ones used on Novas and early Camaro's. Desiring to have the original calipers rebuilt/resleeved, check with White Post in Virginia.
post #6 of 7 (permalink) Old 03-09-2018, 09:02 PM
Quoted: 11 Post(s)
Pinion Head,
Thank you for the recommendation.
Sixty7GTO is offline
post #7 of 7 (permalink) Old 03-12-2018, 11:58 AM
1968gto421's Avatar
Quoted: 72 Post(s)
As usual Pinion Head offers excellent advice. White Post has been around longer than I have doing restoration work (since 1940). When I was in AACA, White Post was the ultimate resto shop to do your antique/classic.
Here's their brake site:
Brake Sleeving & Rebuilding Services ? White Post Restorations
1968gto421 is online now
caliper piston dia. bobh Drive train, suspension, alignment and brakes. 0 08-12-2015 08:39 AM
4 piston disc brake caliper mount bolts chemnick 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 03-04-2014 04:56 PM
caliper piston Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 12-05-2010 08:58 PM
hole in brake caliper Topkat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 11-27-2010 04:11 PM
