1968 Gas Tank neck removal - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-30-2016, 09:41 PM Thread Starter
par4n1's Avatar
Does anyone know the method for removing and reinstalling the original gas tank filler neck? I am finding little to no info anywhere on the web. I want to install it in my new tank.
Thank you
par4n1 is offline
post #2 of 6 (permalink) Old 05-31-2016, 09:38 AM
I believe it's soldered. Fill the tank with water then melt the solder with a torch around the neck to remove it. You'll need some flux to re solder to the new tank.
post #3 of 6 (permalink) Old 06-01-2016, 11:18 PM Thread Starter
par4n1's Avatar
thanks, i bought some map gas and heated the neck. it is sodered and with a little movement it slipped right out.
par4n1 is offline
post #4 of 6 (permalink) Old 07-01-2016, 11:57 AM
Quoted: 9 Post(s)
What is map gas? Did you fill the old tank with water and then heat the neck? Did you solder the neck to the new tank yourself? What type of solder? Thanks.
wishihaditback is offline
post #5 of 6 (permalink) Old 07-01-2016, 12:24 PM
chuckha62's Avatar
Quoted: 18 Post(s)
Map Gas is similar to propane, but burns hotter. Most hardware stores which have propane for soldering, will have Map right next to the propane cylinders. Usually a yellow cylinder.
chuckha62 is offline
post #6 of 6 (permalink) Old 07-01-2016, 01:21 PM
Quoted: 9 Post(s)
Thanks for the map gas reply. Learn something new most everyday.
68 GTO gas tank filler neck? DaveM 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 05-04-2019 02:48 PM
1968 GTO Gas Tank Vent jlarson69 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 10-31-2013 10:58 AM
1968 GTO Gas Tank Manufacturer Stamp voltaire 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 10-14-2013 12:52 PM
Gas tank cage removal enjracing 2004-2006 GTO General Discussion 39 06-19-2006 05:54 PM
how can gas tank cage removal be dangerous? enjracing 2004-2006 GTO General Discussion 18 06-15-2006 04:38 PM
