1969 GTO Fuel Tank - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-12-2019, 12:15 PM Thread Starter
Guenthar's Avatar
1969 GTO Fuel Tank
I have a leak between the filler neck and the tank in my car and have decided to replace the tank. I was wondering if anyone had installed the in-tank fuel pump/ sending unit?
I installed a Painless wiring harness and the fuel pump wire is in the vicinity and just needs the fuse installed to make it hot.
I have some questions, is it a simple conversion? Did you install a regulator before the carburetor? Which brand is recommended and which would you avoid?
I am looking for advice before I make this change, my Edelbrock mechanical fuel pump is only 2 years old, so a new tank/sending unit eliminates the leak.
Marty
Guenthar is online now
post #2 of 2 (permalink) Old 02-12-2019, 07:00 PM
Quoted: 391 Post(s)
Marty
Read through this recent discussion, it may answer a few questions - https://www.gtoforum.com/f178/electr...l-pump-133157/
grinding around fuel tank area should i remove tank ? fiesta62 1964-1974 Tempest, Lemans & GTO General Discussion 7 11-08-2011 08:12 PM
1969 GTO Fuel Tank Replacement CPK1969 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 09-11-2011 02:15 AM
Stock gas tank to ATl Fuel Cell, Fuel pump,ETC??? cpr Drive train, suspension, alignment and brakes. 1 04-29-2009 09:20 AM
Aus gas tank vrs USA tank? GO-GTO! Service, Maintenance and Technical Discussion 23 03-03-2006 11:45 PM
