1970 Torque specs - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-28-2018, 01:34 PM Thread Starter
the1970GTO's Avatar
1970 Torque specs
Could someone please tell me the torque specs on the tie rod outer ends, inner ends, and brake caliper mounting bolts?
Need to get my hands on a shop manual (sources appreciated too), in the meantime if anyone has this info handy I would appreciate it.
Thank you in advance,
Chris
the1970GTO is offline
post #2 of 5 (permalink) Old 05-29-2018, 03:07 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
googles your friend ....
[url]http://www.hotrodreference.com/862/chevelle-and-gm-a-body-front-suspension-torque-settings
most important words first
good luck ..............
BLK69JUDGE is online now
post #3 of 5 (permalink) Old 05-29-2018, 04:22 PM
Quoted: 106 Post(s)
You posted in the 2004-2006 GTO section, I moved your post to the proper section of the forum.
Your manual can be purchased at Ames Performance.
https://secure.amesperf.com/qilan/De...A&web_access=Y
Goat Roper is offline
post #4 of 5 (permalink) Old 05-29-2018, 04:25 PM Thread Starter
the1970GTO's Avatar
Thank you for this. Believe it or not, I did try to google it. I saw that page but as there was no model years listed or referenced, I wasn't sure about it.
Chris
post #5 of 5 (permalink) Old 06-20-2018, 07:48 PM Thread Starter
the1970GTO's Avatar
UPDATE - I purchased the Pontiac service manual and figured I would update this post just in case anyone else needed the information. The torque specs listed in the hotrodreference page on the first reply do NOT seem to match the Pontiac service manual.
From the service manual it appears they should be:
inner tie rod nuts: 60 fl/lb (85 lbs max to insert cotter pin)
outer tie rod nuts: 50 ft/lb (85 lbs max to insert cotter pin)
adjuster sleeve nuts: 20 ft/lbs
Best Regards
Misc 69 Torque Specs dan woodland 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 15 12-13-2016 08:58 PM
Torque Specs Getyourgoat 1964-1974 Tempest, Lemans & GTO General Discussion 6 09-08-2014 05:36 AM
Torque specs 66goatframeoff 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 02-08-2012 01:33 PM
Clutch torque specs? catalina421 Drive train, suspension, alignment and brakes. 7 02-17-2009 08:57 PM
Torque Specs toms66 1964-1974 Tempest, Lemans & GTO General Discussion 1 01-09-2006 08:18 PM
