1974 GTO Fuel Sending Unit Replacement - Pontiac GTO Forum
post #1 of 18 (permalink) Old 08-18-2015, 10:30 PM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
1974 GTO Fuel Sending Unit Repair
Fuel gauge stuck at full, even when tank is empty. Did diagnostics to find out if it was the gauge or the fuel sending unit using ohmmeter. Seems to be the sending unit.
I can't find a replacement fuel sending unit for it. Seems there are fuel sending units available for X-body GM fuel tanks through 1972, but can't find one for 1974. Any suggestions on where to find one would be welcome. I don't want to replace the entire gas tank, want to keep as much original and oem as possible.
Last edited by Red74Goat; 07-31-2017 at 12:19 AM. Reason: I edited the title from "Fuel Sending Unit Replacement" to " Fuel Sending Unit Repair" so that people searching for how to repair their fuel sending units will hit this thread.
Red74Goat is offline
post #2 of 18 (permalink) Old 08-19-2015, 01:47 AM
Quoted: 106 Post(s)
Call CARiD they have them listed for LeMans, you may want to pull yours out to compare.
1974 Pontiac LeMans Replacement Fuel System Parts - CARiD.com
If they don't have it they may be able to tell you who does.
Goat Roper is offline
post #3 of 18 (permalink) Old 08-19-2015, 11:54 PM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
Thanks Goat Roper, I'll check them out and see if I can get a lead from them.
post #4 of 18 (permalink) Old 08-20-2015, 11:32 AM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
I checked with them and unfortunately they don't carry the part. Only suggested checking e-bay and amazon (which I have done for months).
I may have found the fuel sending unit at Auto City Classic.
I will check them out and see if they have one available.
post #5 of 18 (permalink) Old 08-20-2015, 03:20 PM
I would compare to a 74 Nova to see if they interchanged.
BRasi is offline
post #6 of 18 (permalink) Old 08-20-2015, 05:00 PM
Here is a website that offers one for 1972 (FG104C) and another for 1976 (FG103C), Give them a call and see which is the correct to use for 1974,
05GTO is offline
post #7 of 18 (permalink) Old 08-21-2015, 11:40 PM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
BRasi and 05GTO thanks for the suggestions. I checked out a vette forum where there were multiple problems with sending units and there was some success with adding Techron to the tank to remediate sulfur deposits on the sending unit. I added full tank of gas and added Techron, drove around, gauge working now. It had been registering completely full, even with only a couple of gallons of gas in the tank. Not sure if this will last, but sure beats dropping tank and removing sending unit for now! May have been problems with old gas left in tank initially causing the problems with the fuel sending unit.
Thanks.
post #8 of 18 (permalink) Old 08-22-2015, 02:18 PM
68GTO4004Spd's Avatar
Have you checked to see if the sending unit ground wire is connected? That will cause the gage to read full.
68GTO4004Spd is offline
post #9 of 18 (permalink) Old 08-24-2015, 01:15 AM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
68GTO I did check the ground wire and it is/was connected. Thanks.
post #10 of 18 (permalink) Old 04-11-2017, 11:24 PM Thread Starter
Red74Goat's Avatar
Quoted: 4 Post(s)
Bought a fuel sending unit for a 1974 Nova about a year ago, didn't have a chance to drop the gas tank until a few days ago. Unfortunately the Chevy replacement part only has a single fuel line coming out of it, but my Pontiac unit has two lines: one for the fuel and one for the fuel vapor return hose from the fuel pump back to the tank. The fuel vapor return hose connects to the fuel pump, so not having a fuel return line on the Chevy replacement part I bought would have started me down a whole different trail of mods, which I don't have any interest in doing at this time. So I decided to pull the original sending unit, disassemble it, and clean the rheostat contacts to see if that would fix it.
My unit is a 0-90 ohm unit, with 0 ohms for empty and 90 ohms for full. I reassembled the sending unit rheostat this evening and checked it out of the car with an ohmmeter across the full movement of the float, from empty to full, and it has a 90 ohm variance. Next I will check it by connecting it to the fuel gauge in the car before installing it back into the tank and reinstalling the tank.
I'll post few pics of the unit from my GTO in the following post.
68 gto fuel sending unit wings012345 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 07-07-2015 08:33 PM
68 GTO Fuel Gauge Sending Unit mwatson1647 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 10-13-2014 08:34 AM
Fuel sending unit Piedog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-09-2013 09:14 AM
Fuel sending unit/fuel gauge issue xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-08-2012 08:12 PM
A.C. car fuel sending unit asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 04-23-2008 12:07 PM
