'65 GTO Fuel Line(s)? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 11-24-2016, 06:01 PM Thread Starter
Roqetman's Avatar
Quoted: 16 Post(s)
It's my understanding that '65 GTOs do not have a return fuel line however, mine has two steel lines that appear to be original. It has PS, PB, AT, factory AC. One line measures 5/16" O.D. And connects to the fuel pick-up/sending unit in the tank. The other measures 1/4" O.D. I presume the 1/4" line is a return line but do not what it should connect to on the engine, i.e. Fuel pump, carb? I do not know the purpose on this return line. I bought a new fuel tank sending unit but it too has provisions for the return line. My plan is to block off the 1/4 line but just wanted to know why it's there and what should it connect to. My car also has vent tube near the gas filler tube so I would think the 1/4 line is a vent line(?). Any advice on this is greatly appreciated. Thanks!
Roqetman is offline
post #2 of 4 (permalink) Old 11-24-2016, 06:15 PM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
'66 AC equipped cars had a vapor return line that ran back to filler neck to a "U" shaped vent pipe.
I think '65 is the same for cars with AC.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 4 (permalink) Old 11-27-2016, 01:30 PM Thread Starter
Roqetman's Avatar
Quoted: 16 Post(s)
Thanks for your reply. My 65 has a fitting on the tank sending unit for the fuel line return (1/4" OD). But what does it connect to on the engine? The original carter fuel pump nor the new Edelbrock fuel pump has any provision for a return line. Does the return line connect to one of the ports on the Q-Jet?
Roqetman is offline
post #4 of 4 (permalink) Old 11-27-2016, 05:18 PM
El Monte Slim's Avatar
Quoted: 14 Post(s)
Using the correct fuel filter
The return line connects to the small outlet on the correct fuel filter, AC GF-98.
You can see it here :https://secure.amesperf.com/qilan/De...A&web_access=Y
El Monte Slim is offline
Brake line/ fuel line supplier greenjudge69 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 10-14-2015 07:44 AM
67 GTO Fuel Line RGF 67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 12-28-2012 09:55 AM
69 gto fuel return line A69GTO 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-14-2011 11:10 AM
66 GTO fuel line DRD57 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 12-03-2009 07:34 PM
