66 GTO Brake booster/master cylinder - Pontiac GTO Forum
post #1 of 6 (permalink) Old 09-28-2017, 04:58 PM Thread Starter
El Monte Slim's Avatar
Quoted: 14 Post(s)
I have a friend (not on this forum) that has a nice very original driver. He wants to upgrade to a dual master cylinder and keep things looking as original as possible.
Here are the questions.
1. Will a stock 1967 dual master cylinder fit on and work with a stock 1966 power brake booster?
2. If not, and you use a 1967 dual master cylinder and power booster, will that work and fit?
Thanks for your replies.
El Monte Slim is offline
post #2 of 6 (permalink) Old 10-22-2017, 05:30 PM Thread Starter
Quoted: 14 Post(s)
The sounds of silence...
No one has done this???
post #3 of 6 (permalink) Old 10-22-2017, 06:04 PM
Quoted: 390 Post(s)
I would hit Pinion head with a PM. He would probably know if the power boosters were the same. The parts catalogs seem to show a different part number for the '66 vs '67 power booster, so my guess is that putting a '67 MC on the '66 power booster may not work. It seems the '64-'66 are the same and '67 and up are the same.
So I would think that the other option would be installing the '67 power booster/MC combo if there were no problems with the brake pedal geometry. It may be that your friend would also need to swap out his '66 brake pedal for a '67 brake pedal to match the dual MC combo if there are any differences.
post #4 of 6 (permalink) Old 10-27-2017, 02:31 PM
Quoted: 155 Post(s)
I am actually looking at similar options and am leaning towards a hydra boost (vs vacuum) setup.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #5 of 6 (permalink) Old 10-27-2017, 03:06 PM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
I didn't answer because I don't know.
That said, my guess is it will work either way.
64GTOConvertible is offline
post #6 of 6 (permalink) Old 10-27-2017, 08:10 PM
Quoted: 390 Post(s)
Found a diagram of both the '66 and '67 power booster and they are indeed different. The same book states that the '66 vs '67 brake pedal is also different.
So, my best guess would be that in order to do the swap, short of purchasing an aftermarket set-up, is that you would need to treat the swap as a 1967 dual master cylinder/power booster set-up, complete with the correct lines/distribution block and brake pedal.
Again, never did this, no expert on this, and the information is what I found in going through my Pontiac resources.
1967 GTO leak between booster/master cylinder mike1967gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 11-02-2013 05:18 PM
'69 GTO Booster/Master cylinder problems Turley 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 08-24-2012 08:44 PM
rebuliding master cylinder & booster Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-04-2010 08:28 PM
Which late model booster and master cylinder??? ponchonorm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 06-26-2009 04:54 AM
