67 Drum Master Cylinder Question - Pontiac GTO Forum
post #1 of 14 (permalink) Old 05-02-2018, 07:22 AM Thread Starter
Quoted: 5 Post(s)
Hi everyone,
I have a 1967 GTO with all drums and no power boost.
I recently noticed a drop in brake fluid. I keep a catch pan under the car (just in case!) and thought it was coming from the distribution block. After a thorough search I could not find anything leaking. I had my wife apply pressure to the pedal and immediately noticed a tiny squirt out of a hole on the passenger side of the master cylinder. The hole is about a 1/4 inch diameter and all the way at the back of the cylinder, just in front of the mounting flange. Is this a breather hole and the fluid is showing a seal failure (fluid leaking past the seals on the plunger)? Or did something loosen and fall out of that hole such as a set screw plug? I can't get a good look in there to see if it has threads or not and I could not feel any with a screwdriver tip. I also can not find a picture of the passenger side of a master cylinder online. Can anyone explain that hole? From what I can tell, it might be the original master cylinder so a failure would not be unexpected.
Also, rebuild or replace? I'm thinking the price of a new one is relatively low so I might replace and after the summer, rebuild the original. Appreciate any help.
supergrizzly is offline
post #2 of 14 (permalink) Old 05-02-2018, 07:51 AM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
Shouldn't be weeping, so you have a failure.
"New" is probably rebuilt, or more properly "remanufactured" meaning the bore has been cleaned up before reassembly. You can rebuild yours or go the "new" route, all the same in the end (unless there are date codes or some such you want to keep with an "all original" motif)
64GTOConvertible is offline
post #3 of 14 (permalink) Old 05-02-2018, 08:09 AM
JNYBOY's Avatar
Quoted: 5 Post(s)
This master came off my 66' with the power boost. It does have a bleeder on the pass. side ... I installed a dual master with a set of discs on the front for safety reasons....Hope these pics help....J...
ID:	110082   Click image for larger version
ID:	110090   Click image for larger version
JNYBOY is offline
post #4 of 14 (permalink) Old 05-02-2018, 08:26 AM Thread Starter
Quoted: 5 Post(s)
JNYBOY,
Same location as your '66 but mine has no fitting in the hole as your picture shows. Maybe it fell out? The leak started suddenly and has not gotten worse. Hate to order a new one if it is just a fitting that loosened and fell out.
Good advice 64, will probably go the "new one " route unless it is just a fitting. Will check better tonight for threads in that hole.
Thanks all.
post #5 of 14 (permalink) Old 05-02-2018, 08:48 AM Thread Starter
Quoted: 5 Post(s)
This is the hole I am speaking of. The rear hole near the flange. It is on both sides of the unit. Almost looks like a locating hole for machining purposes so I'm really confused why fluid would come out there.
ID:	110106   Click image for larger version
Name:	image1 (003).JPG
post #6 of 14 (permalink) Old 05-02-2018, 09:10 AM
JNYBOY's Avatar
Quoted: 5 Post(s)
....That hole should not be a source of a leak, as it is a hole that goes all the way through to the other side. Not a bleeder hole, and no fitting or threads in there. ...Sure of the source of the leak ?....Best, J
JNYBOY is offline
post #7 of 14 (permalink) Old 05-02-2018, 09:56 AM Thread Starter
Quoted: 5 Post(s)
Gong to double check that tonight! Weird. When the pedal was pushed it actually blew out of that hole. More investigating to come.
post #8 of 14 (permalink) Old 05-04-2018, 08:08 AM Thread Starter
Quoted: 5 Post(s)
So after a better look with more lighting it seems as if the leak is originating around the reservoir top where the cap sits. The gasket/diaphragm on the cap looks good and the bar seems to snap it down tightly. I started by cleaning everything I could around the master cylinder, topped of the reservoir and took it for a quick spin. When I came back it was slowly dripping at that same hole but I noticed the passenger side of the reservoir was wet from the top down. I had not noticed that before. Can that gasket/diaphragm be the issue or am I somehow creating too much pressure within the reservoir? Can that gasket/diaphragm just be replaced?
post #9 of 14 (permalink) Old 05-04-2018, 10:11 AM
JNYBOY's Avatar
Quoted: 5 Post(s)
[QUOTE=supergrizzly;858098]So after a better look with more lighting it seems as if the leak is originating around the reservoir top where the cap sits. The gasket/diaphragm on the cap looks good and the bar seems to snap it down tightly. I started by cleaning everything I could around the master cylinder, topped of the reservoir and took it for a quick spin. When I came back it was slowly dripping at that same hole but I noticed the passenger side of the reservoir was wet from the top down. I had not noticed that before. Can that gasket/diaphragm be the issue or am I somehow creating too much pressure within the reservoir? Can that gasket/diaphragm just be replaced?
....The G/D sounds likely. Replace the diaphragm (Cheap, no effort fix)...too much pressure ?, No Way !
Make sure that your retaining spring/clamp is a tight fit. ....Good Luck !
JNYBOY is offline
post #10 of 14 (permalink) Old 05-04-2018, 11:51 AM Thread Starter
Quoted: 5 Post(s)
Thanks for the help. Much appreciated.
Replacement master cylinder for manual disc/drum 1968 GTO Burger 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 04-10-2015 08:48 AM
Clutch Master cylinder johnfin Service, Maintenance and Technical Discussion 1 08-24-2013 03:13 AM
'65 GTO disc brake/ master cylinder question PontiacDave 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 01-17-2011 09:25 PM
Switch master cylinder Richtenb Drive train, suspension, alignment and brakes. 1 04-15-2010 04:57 AM
master cylinder question 66tempestGT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-12-2010 07:35 AM
