67 GTO Exhaust Question - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-14-2016, 01:45 PM Thread Starter
My GTO has the base 400 ci engine with cast iron manifolds and an 066 camshaft. It runs good but just doesn't seem as responsive as I think it should be. Plugs, points and timing are set as per the factory manual.
I looked at the exhaust pipes and mufflers after noticing that things didn't look quite right. They looked to be fairly new (stainless) but
I started measuring them.
Front pipes were 2" OD and tail pipes were 2.25 OD. Mufflers seem to be some no name turbo muffler at 14".
Does this sound like it could cause the engine to be a bit weak and not as responsive? I know I should have 2.25" for the front pipes and 2" with resonators for the tail pipes.
I am curious on how much of a bearing these smaller exhaust pipes have on performance.
67 Tiger is offline
post #2 of 2 (permalink) Old 06-14-2016, 05:03 PM
Quoted: 390 Post(s)
The 066 cam is not much of a cam and was not used in the GTO for '67. It was used in full size cars and Firebird. HP rating with that cam was 325HP. In '67 there was a low compression gas regular fuel 400 rated at 255HP which came in the GTO as well. It used the "254" cam. Now I don't know what "base 400" means to you, but if you have a low compression base 400, you won't have a lot of get-up-and-go.
Your pipes shouldn't really be the problem with the 066 cam.
1965 GTO Ram Air Restorations Exhaust Manifolds - Downpipe Question hooperk 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 06-29-2012 04:35 AM
69 GTO Exhaust question josemusclecar 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 7 09-22-2008 09:51 PM
New Owner / GTO Exhaust Question BrienCharles 2004-2006 GTO General Discussion 6 03-23-2008 08:30 PM
70 GTO 455 Exhaust Manifold leak question 70455goat Engine Discussions 2 11-09-2007 02:31 PM
Exhaust Question GTO_Addict Intake and Exhaust Discussions 10 05-18-2007 11:23 PM
