67 HO battery cable tube and shield - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-01-2016, 09:49 AM Thread Starter
I'm installing repro H O manifolds on my 66 and am wanting to route the battery cable like the factory did on the 67 H O cars. I see the cables are available, but can't find the other parts to do the job. Any ideas where I can find the actual parts or an illustration? Thanks, Dave
lugnutx2 is offline
post #2 of 3 (permalink) Old 01-01-2016, 09:58 AM
Quoted: 106 Post(s)
Inline Tube has the tube that goes on the motor mount and M and H has the harness.
I did this on my '67, you may have to drill the mount, template comes with the tube.
Once you mount the tube use a large screwdriver to kink it for max clearance from the manifold.
Goat Roper is offline
post #3 of 3 (permalink) Old 01-01-2016, 12:58 PM Thread Starter
Thanks!
lugnutx2 is offline
Battery Cable Routing MAP53 1964-1974 Tempest, Lemans & GTO General Discussion 4 04-12-2014 07:23 AM
Positive Battery Cable Shield voltaire 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 10-16-2013 09:40 AM
Starter wire heat shield tube BrianLeith 1964-1974 Tempest, Lemans & GTO General Discussion 7 04-14-2013 11:07 AM
New Battery Cable Oldeboy 1964-1974 Tempest, Lemans & GTO General Discussion 2 03-23-2013 10:15 AM
battery cable tube Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 9 07-07-2011 04:14 PM
