67 Lemans - Wagon Coil Springs - Pontiac GTO Forum
post #1 of 13 (permalink) Old 07-24-2015, 02:17 PM Thread Starter
I'm replacing the coil springs all around on my 67 Lemans and decided to order the wagon springs to raise the rear end a bit. I've seen a few people mention making the same change on their cars and needing shock extensions so the shocks to don't top-out.
Does anyone know what size extension is needed or do I just have to install them and do some measuring?
RexInTheCity is offline
post #2 of 13 (permalink) Old 07-24-2015, 05:35 PM
rickm's Avatar
Quoted: 5 Post(s)
Im not sure if the same applies for a '67, because they changed the design of the springs. but a set of convertible rear coils for a '64-'66 coupe or hardtop will raise the car slightly and give it a more aggressive stance without the need to play around with shock travel. I installed a set on my '65 years ago and im happy with them. I did the same to my '64 in the mid '70s. maybe someone with a '67 could advise you on what you need.
rickm is offline
post #3 of 13 (permalink) Old 07-24-2015, 06:50 PM
Quoted: 117 Post(s)
Be ready for wheel hop. Cars raised in the rear love to do it.
post #4 of 13 (permalink) Old 07-24-2015, 11:44 PM Thread Starter
Under what conditions? Normal city driving or hard take offs?
post #5 of 13 (permalink) Old 07-25-2015, 03:58 PM
Quoted: 117 Post(s)
Hard take offs. You can fit no-hop bars and eliminate the hop, though. It can get pretty nasty under power or on wet pavement.
post #6 of 13 (permalink) Old 07-31-2015, 11:33 AM
I put the wagon springs on my 66 years ago, and it raised it too much (for me). I recall it was at least a couple of inches. The convertible springs that rickm suggested may be better. I put Air Lift bags in my stock springs, plumbed separately with the valves behind the license plate so I can stagger the air for wheel hop or add air if I am going to carry around some of my more rotund buddies. The bags last a few or more years and one will crack, so then you buy another set and replace them one at a time.
magnumea is offline
post #7 of 13 (permalink) Old 07-31-2015, 12:52 PM Thread Starter
I'll find out tomorrow if it sits too high . At least it's a relatively cheap experiment.
post #8 of 13 (permalink) Old 08-01-2015, 01:58 PM Thread Starter
Took 5 hours and a trip to AutoZone and Sonic but I got the rear springs in. I think the longer springs made lining the shocks up a bit harder. Had one stubborn bolt on both sides that didn't want to line up without a bit of effort.
I'd say I'm up 5-6 inches over the original worn out springs.
Not sure how I like it yet, we'll see what it looks like after I get the front springs in tomorrow.
ID:	61881   Click image for larger version
ID:	61889   Click image for larger version
post #9 of 13 (permalink) Old 08-01-2015, 03:55 PM
rickm's Avatar
Quoted: 5 Post(s)
not tryin to insult you, but that looks way too high to me. just my opinion. my convertible rear springs bring the wheelwell moulding just to the top of the tire.
rickm is offline
post #10 of 13 (permalink) Old 08-01-2015, 04:43 PM Thread Starter
So was excited to get started this morning and didn't check the part numbers before I got started. Long story short I installed the wrong springs... I'll post new pics when I get it fixed tomorrow.
Coil Over Springs knucklehead12 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 6 04-01-2015 09:19 PM
coil springs on a 65 qwkvet 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 10-28-2014 12:03 PM
rear coil springs instead of leaf springs jtwoods4 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 01-02-2012 09:52 PM
Coil Springs? ponchonorm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 07-23-2009 04:06 PM
