67 Rear Drum Brake - Pontiac GTO Forum
post #1 of 2 (permalink) Old 12-20-2015, 12:26 AM Thread Starter
67 Rear Drum Brake
Ok....
Im doing a complete frame off on my 67 GTO but im stumped on the rear brake drum. Here is the situation when I took the rear drum cap off there was a wheel cylinder that was a 15/16 bore. When I go to look up replacement parts for the 67 the only one that pops up is a wheel cylinder with a 7/8 bore. I went ahead and ordered the one with a 7/8 bore and put it on the backing plate now the problem is when I put the pistons on the wheel cylinder it pushes the brake pads all the way out and there is no way that I can push the cylinder in any more. Im starting to wonder if maybe once in the car life time if the rear end was switched out with a 66 or maybe im just not getting it right. When I look at the other side with the 15/16 bore everything is sitting in place correctly. If I was to order the 15/16 bore and place it back on there would it effect anything? Will my brake lines still fit? Just to give you a run down on what I have going on. I did a disc brake conversion on the front and the portioning valve is a Disc/Drum set up now. Also, the I have also added a brake booster for power assist. Thanks in advance.
67PONGOAT is offline
post #2 of 2 (permalink) Old 12-20-2015, 02:20 PM
'64-72 Pontiac A body station wagons typically had 1/16" larger diam wheel cylinders. Olds and Buick A body's used wider drums and wider sealed axle bearing axles, often different rear backing plates, and the oddball wheel bearings used on the early Buick and Olds a body SW's are a PITA to source replacements for.
45+ years of brake jobs...Over the years, wheel cylinders were often replaced. Occasionally, entire loaded backing plates have also been swapped out, not just rears, so not that surprising. Substituting 1/16" larger bore wheel cylinders has been a fairly popular mod for decades, typically it's combined with a slightly larger bore master cylinder. I have a couple pair of A body SW wheel cylinders, will be doing a comprehensive comparison braking test with, combined with special matrix shoes, stiffer return springs, and cryoed drums. the special matrixshoes and springs are from Muscle Car Brakes.
Need help with rear drum parking brake adjustment BierManVA 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 02-10-2015 02:01 PM
Rear drum brake woes SPCMarty 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 11 04-28-2013 08:02 AM
69 GTO Rear Drum to Disc Brake Conversion Kit jtwoods4 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 02-11-2012 04:55 PM
Rear Drum Parking Brake Not Working jtwoods4 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 01-12-2012 08:21 AM
Drum Brake Help Falco21 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 07-20-2011 05:01 PM
