68 GTO HD Shocks - Pontiac GTO Forum
 3Likes
  • 2 Post By BearGFR
  • 1 Post By 1968gto421
post #1 of 4 (permalink) Old 11-30-2018, 08:05 AM Thread Starter
I have a mostly original 68 GTO that came with factory HD shocks/suspension. I am having a difficult time finding replacements for them. The description for most shocks for the car say "except for Heavy Duty Suspension". I was told by the original owner not to replace with regular shocks (car currently has air shocks that he installed for towing a trailer). Any help would be appreciated. Thanks.
68 GeeTO is offline
post #2 of 4 (permalink) Old 11-30-2018, 12:20 PM
First thing, ditch the air shocks. The shock mounting points were not designed to carry the weight of the car and can be damaged, if they haven't been already. Using them to enable pulling a trailer on that car has only made that more likely from the increased weight due to the trailer tongue, so be sure to thoroughly inspect both the upper and lower shock mounts for any signs of deformation or damage. You will encounter people who will swear, "I've used air shocks for years and have never had a problem." I'm happy for them having been so fortunate, but you will also find people who either have caused damage from doing it, or perhaps just have not yet discovered it.
With that in mind, remember what the real function of a shock absorber is. It is NOT supposed to carry the weight of the vehicle or affect ride height. It's job is to dampen then action of the springs, for example so that they don't continue to 'bounce' when they've been deflected. "Heavy duty" shocks are going to be more resistant to movement, so they're going to result in a harsher ride: you're going to "feel" the bumps more. Even though the original Pontiac shocks may not be available (I don't know, I haven't looked for them), you should be able to find quality aftermarket shocks that are at least as 'stiff' as they were if not stiffer. I'd contact some reputable quality vendors (KYB, Strange, QA1, etc.) and discuss your needs with their tech people. That's what they're there for.
1968gto421 and 68 GeeTO like this.
post #3 of 4 (permalink) Old 12-01-2018, 04:31 AM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
Super Lift shocks were offered from PMD with engineered air shocks and work as intended when used as intended.
However lots of meatheads use them as BAND-AIDs FOR old weak springs.
The sky will not fall if you have everything in order.
Cheers.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #4 of 4 (permalink) Old 12-01-2018, 11:05 AM
1968gto421's Avatar
Quoted: 72 Post(s)
I have found Bilsteins to work well for me on my GTO. The others mentioned by Bear are excellent. As Bear said; do talk with their tech people.
68 GeeTO likes this.
1968gto421 is offline
1966 GTO 3speed HD trans shifter with Console richde 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 07-09-2013 06:25 PM
