69 custom s pypes down pypes issue - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-17-2016, 02:12 PM Thread Starter
REDMAN's Avatar
I recently purchased the pypes 2 1/2 stainless exhaust with x pipe from pypes for my 69 custom s stock 350 . When I installed the down pipes the right side hits the transmission pan on my stock th350. Has anyone else had this problem and if so what did you do if anything? I was thinking possibly taking it to an exhaust shop to make a slight bend in the pipe, Im thinking I dont want the heat from the exhaust transferring to the tranny. Any thoughts or solutions would be great.
REDMAN is offline
post #2 of 4 (permalink) Old 09-17-2016, 02:56 PM
Quoted: 106 Post(s)
My '67 came with the Pypes transmission heater system, it was also loud and obnoxious with Magnaflows.
Rather than mess with it I just removed it and replaced it with a Gardner factory reproduction exhaust with resonators.
1967 GTO Exhaust Systems - Gardner Exhaust Systems - 1967 GTO Exhaust Sytems by Gardner
Kind of pricey but I wanted factory correct and factory sound.
If you don't want to go that route your idea of having a muffler shop reconfigure it isn't a bad idea.
If you want a crossover have them remove the X and do the crossover behind the tranny tailpiece.
My manifolds are HO so I had Eric configure the head pipes with new collars and the fit and finish are a 10.
Goat Roper is offline
post #3 of 4 (permalink) Old 09-17-2016, 05:01 PM
Redman, with the problem your having, I'd take some digital pics of the passenger side headpipe, then during a weekday, call the tech help at PYPES, be prepared to email the pics. Chris' staff should work to remedy the problem.
post #4 of 4 (permalink) Old 09-18-2016, 07:49 PM Thread Starter
REDMAN's Avatar
Thank you both for the reply. I had read on a couple reviews of guys having the same problem but only a couple out of several so mabe the others didnt realize the heat transfer form the exhaust could damage the tranny. Any way I did price the gardner exhaust but little pricey for me and wanted something more aggressive for less cash. I am very happy with the pypes sound versus flowmasters which I have always used in the past. Besides this small hicup I am impressed. I used some pypes products in the past on other projects but never the mufflers. I used the street pro mufflers and am very happy with them. Replaced flowmaster 44 by the way. Anyway I only installed the headpipes and mufflers because the exhaust showed up mid sat and had a car show at my friends house at 500. My old exhaust had fell off so it was a rush job. I will install the x pipe and tail pipes later this week and update the thread in case anyone is interested in the same setup.
REDMAN is offline
Custom Pypes/Borla XS '04 system svede1212 Intake and Exhaust Discussions 13 12-12-2012 05:01 PM
67 Pypes install lam63 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-12-2012 08:33 AM
Pypes Exhaust? dreiser1651 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 12 09-21-2010 05:14 PM
Pypes vs Flowmaster Mcantw 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 11-09-2009 04:02 PM
pypes violators Pontiac Tempest Cstm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 03-10-2009 08:12 PM
